The HVBJB is under a current recall. But it’s entirely different than what the OP was having done. We are all getting a new HVBJB.Right now my 2021 Premium is in for a high-voltage battery warning and a powertrain malfunction/reduce power alerts. Dealer says the need to replace the High Voltage Battery Junction Box and for some reason the are also replacing both front axles. I don't think the two are related...... Any thoughts are welcome. Thanks!!
Slight knock on hard turns, thought it was more like a tie rod. OK with me getting new axles.The HVBJB is under a current recall. But it’s entirely different than what the OP was having done. We are all getting a new HVBJB.
Axles- not sure. Were you having issues?
Search the forum for 'half-shaft' - in short, known issue, easy fix by the dealer. Went through it myself.Slight knock on hard turns, thought it was more like a tie rod. OK with me getting new axles.
Thanks for the reply.
Hmm, I may have that issue myself. I wish I had them look at that during the recall.Search the forum for 'half-shaft' - in short, known issue, easy fix by the dealer. Went through it myself.
It's a half-day (if that) repair. Might even be able to do it while you wait if you're willing.Hmm, I may have that issue myself. I wish I had them look at that during the recall.
