Option to wireless charging - my modification solution
markw314
Sterling, VA
2023 Mach-E GT
This little charger right here plugged in at home in the wall. This thing will take it from 50% to 100 and like 20 minutes. Take it out put it in the USB port in the car. It just sits at the same percent the whole time you’re driving, so gotta figure out a way to make as much power coming out of the socket on the wall, but I guess you need some type of inverter from the cigarette lighter port because it didn’t make any difference. Plugging in adapter and plugging the USB into that either.
You can barely pull that off the back of the phone and it sits perfectly in the little tray
It is USB-C on the other end? I find that port much more powerful than the USB-A port.
Fins160
JP
Tempe, AZ
2022 MachE Select C/T Dark Matter Gray
why they had to take the design and push the cam lens out extra quarter to 16 of an inch causing anything delayed flat impossible,
Almost everyone uses a MagSafe case on their iPhone, which allows it to lay flat and get a fast charge from MagSafe chargers like the TWRAPS.
Are you rocking the iPhone 14 with no case?
Ford Mustang Mach-E Option to wireless charging - my modification solution 1722006292718-0r
Jerrytball
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
No, I have a MagSafe case
Jerrytball
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
As I said before, the wraps charger worked fine. The camera hung below and the phone stuck to it, but driving around an hour my phone charged like 3%, which is ridiculously slow.
Jerrytball
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
Not the worst location and you barely see a wire
Ford Mustang Mach-E Option to wireless charging - my modification solution image
Jerrytball
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
So here’s what it looks like from the backseat. It’s not a bad set up. That little brown thing is just something I put their temporary lead to hold the table in place. And it’s nice and cool. That’s really a good holder. This thing is something I had in an old CX seven.
And because my USB drive, you can flip it around to a C or an a I’ve actually got my music and so I’ve got my phone charging so it’s working. I went ahead and put the wireless back in the car just in case something ever changes or I decide to get an iPhone 8 Plus again.
Ford Mustang Mach-E Option to wireless charging - my modification solution IMG_8295
Tcevwa
Tonya
Eatonville, Washington
2023 Mustang Mach E GT
burritoman
2023 Mach-E Premium, Ford Edge
I’m basically putting up with this iPhone 14 Pro Max I’m gonna be going to the 16 in September so I’m hoping a lot of stuff will be resolved. I used to be an android and I just found the iPhone was more friendlier to use for me. I have nothing against the android other than I can’t send you a video if you have one that’s still an issue which is ridiculous.
iOS 18 fixes that issue by finally adding RCS implementation into Messages. This allows for fully featured messaging between iOS and Android. One less reason to stay with Apple I guess, but all my stuff is Apple and I like the integration between all the devices.
Jerrytball
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
Jerrytball
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
I went with this solution, kind of matches the theme of the car, with the electronics look, it does charge really well wirelessly, the only reason there’s a plug is that plugs for the wireless. You don’t have to plug it into the phone, it opens up closes automatically, Nice little charger. For phones that cannot wireless charge it does have these little plugs that go in the bottom of the phone that contacts the little magnet on the holder to sort of make it wireless. And for some reason, the vent on these mustangs are deeper so the little vent mount came up little short. One more edit, it does match the unbridled theme color?
Ford Mustang Mach-E Option to wireless charging - my modification solution IMG_8603
