PALSAPP - It’s GONE! :)
So, I just checked PALSAPP for the 100th or so time today and instead of the source/dest of Kansas City/Birmingham, it now says VIN number not found. The unit may have been moved by another carrier.
Are there still horse rustlers in the west or something?
Seriously, any ideas what this means?
CHeil402
King of Prussia, PA
2017 Audi A4, 2021 MME
Electrical Engineer
CHeil402
King of Prussia, PA
Electrical Engineer
Grux40
Jason
Mach-E Premium RWD Ext. Range - Infinite Blue
CTO
Mine is gone now too. Delivered to Louisville on Monday 3/22 and kept checking for the next BOL/Freight bill to show up for the final leg but it's gone. The Ford Vehicle Order Tracking doesnt work for me. The order number field is only 4 digits and order numbers are 8 digits? I tried first 4, last 4 etc. No dice.
I did stop into my dealer this evening and took the demo out for a spin. That was a mistake. -especially now that I cant obsessively track delivery.
TheSeg
Seg
San Francisco Bay Area, CA
seg.fyi
2021 Mach-E Premium EB-RWD (Built: Feb 2021)
I checked every VIN I have and could find, which includes delivered VINs. All have the same error message. The data coming down the pipe is actually an empty object for each request.
Because the delivered (previously valid VINs and completed shipping) VINs and trip numbers are returning the same empty data. I'm concluding this means nothing to any of our car orders. Something's down on Palsapp whether by intention or by accident.
With more information I can change my opinion, but for now it's simply the reporting site isn't working properly for unknown reason (to me).
EVguy
Rick
Covington, GA
2021 MME Star White Premium AWD ER
Your Dealer has the 4 digit order #. You will have to contact them for that so you can use the Ford Vehicle Order tracking. Also, if you saved a copy of the window sticker, you can get the order # in the bottom left area ust below the RAIL block. You will see item # like "21-2222 O/T 1". The order # are the 4 digits following the hyphen.
When my Mach E was being shipped back and forth, my original entry disappeared from Palsapp like yours. However, I could still find it when I entered the original Freight Bill # instead of the VIN.
Now, if only I had saved the original freight bill number ?
Grux40
Jason
CTO
Your Dealer has the 4 digit order #. You will have to contact them for that so you can use the Ford Vehicle Order tracking. Also, if you saved a copy of the window sticker, you can get the order # in the bottom left area ust below the RAIL block. You will see item # like "21-2222 O/T 1". The order # are the 4 digits following the hyphen..
Perfect. Thank you!
Edit - Good news is that worked. Bad news - new ETA is now 5/17. Damn.
By the way, where are people getting Bills of Lading and Freight Bills?
Papa T
Treven
Birmingham, AL
BMW X1
I would do a screen capture, but I can no longer pull my VIN in Palsapp. However, if you enter your VIN and get a result, there is typically a hyper-link in the far right column of the results. This should pull up a freight bill.
Edit: Found a previous post with the screen capture:
Ford Mustang Mach-E PALSAPP - It’s GONE! :) 1616756467999
The hyperlink that says Delivery Receipt(1).
ajmartineau
Washington
2021 Mach-E
I guess they are on to us. We used up too much bandwidth over the last six months. We've been cutoff.
