Passcode to Start did not work without phone
Striike
Tennessee
2021 Mustang Mach-e (RWD, Select)
Today when leaving the gym, I tried to utilize the passcode to start my MachE. For some reason, the keyboard would not show up until my wife got within range of the car with my phone, which I use as a key. Is this intended behavior? Or was this just a glitch? Am I stranded if my cell phone gets lost or dies?
That's a glitch, keep trying and pressing the brake pedal multiple times until the keyboard shows up. You may need to tap in the password field to get the cursor and keyboard to appear.
Art
Art
244SnowyGv932nFordC
Mustang Mach E
Retiref
Too bad you don't have a FOB. That works all the time.
Homestead
Oregun
23 Mach-E, F-350
Retired Engineer
Mine usually times out a second after the keyboard appears. Yes, tap on the screen and press the brake/start button until the keyboard appears. Usually takes 2 times on mine.
jmcbrew
Jesse
Annapolis, MD
2023 Mach-E Select RWD, vapor blue
Just to cover all the bases — you did try to start the car (brake+start button) right? You won’t get the keyboard until you do that. Even then, it probably takes a few seconds to appear.
stoopid
Las Vegas, NV
2024 MME Select, RWD, Standard Range, Ford Charge Station Pro
I tested my door code and start password recently, I made sure my phone was nowhere near the vehicle at the time and had no issues like you describe. Some good suggests above regarding why it didn't seem to work, or at worse just a glitch.
