Rear wiper size
Hoff
James
Kirkland
2023 Mustang Mach-E
How large of a wiper blade can be installed on a 2023 Mach E. Factory is pretty small. Aldo where can you purchase such?
The Trico 15-G (15”) and Bosch A401H (16”) both fit. The Trico is more flexible than the Bosch so it wipes wider over the convex rear glass. Due to its greater length, the Bosch wipes higher than the Trico. ??
I've been happy with the Trico 15-G.
PedroDaGr8
WA, USA
2021 Mach E Premium (First Edition)
I have the Trico (if memory serves me) and it is amazing the difference it makes over the stock wiper. The stock wiper is just ridiculously undersized.
This.
I’m driving the dealer’s loaner Mach-e atm as mine is (finally) getting the recalls done. The loaner has stock blades on the rear window and they’re almost useless. Go with the longer Trico blades @James Hofg.
DeusEx
New York
2023.5 Mach-E Premium ER AWD
I've purchased the 15 inch blade that is made for the Ford Edge. It also unofficially works and fits perfectly for the Mach-E. Just search and purchase part number FT4Z-17528-DA.
It's hard to go wrong with either the Trico or the Bosch. My rear dash cam is positioned at the top of my rear window so the higher swipe of the Bosch A401H helps a little. I did like the wider swipe of the Trico and because of the way it conforms to the glass it looks a little more factory-like. The Bosch is a little janky looking at rest. ??
txaggies07
Aaron
2021 MachE FE Rapid Red
I have used both the Trico 15-G and the Bosch 16. I prefer the Bosch, but really can't go wrong with either.
