Replacement wheels for 2024 Mach-E Rally?
iroh198412
Iroh
Texas
Mach e 2023 CR1
Looking to replace the 24 rally wheels with something that is identical in spec.
I see they should be 19x8, 47 offset and 63.4 bore. Which wheels would work as a replacement?
Thanks!
spartan
SE Michigan
2013 Focus ST; 1996 Camaro Z28
I believe the stock wheels are 19x7.5, not 19x8.
Tire Rack would be my first suggestion to look, they even have a visualizer tool so you can see what the wheels would look like on your vehicle.
iroh198412
Iroh
Texas
Mach e 2023 CR1
When I chose rally TR says no wheels available. If I filter by specs and then have to choose a car to check if it fits TR says this does not fit.
iroh198412
Iroh
Texas
Mach e 2023 CR1
If it’s 7.5 then the original premium wheels should fit. Thanks.
spartan
SE Michigan
The wheel size is the same as the new-style 2024 Premium (pre-2024 Premium was 19x7). you could look at that as a surrogate
MargaritavilleNH
NH
2021 Mach E GT 2025 Mach E GT Rally
So why won't tirerack sell/recommend any rim for a 24 or 25 Rally?
The Rally is probably not in their database. Put the GT-Performance Edition in since the Rally is an option on the GT platform. The main points of pain would be the body, which is the same on all MMEs, and the front brakes, which are the same on the Rally and the MME GT-PE (and 2024-up GT). ??
@iroh198412 what is the purpose in replacing the Rally wheels? Are you looking for a different design? Are you looking for something lighter? I ask because when I was looking for replacement tires for my GT-PE I wanted wider than stock tires and a specific wheel dimension. I ended up going with a custom forged wheel so that I can run the tire pressure I want to run with 275s. If there is a look you are going after with a specific size you can always go with a custom wheel. ?‍♂?
MargaritavilleNH
NH
I just want the option of carrying a spare tire. I drive 60 miles to work on the interstate, most of the year in the dark, and would like to insure that a flat tire does not end up causing a tow.
MargaritavilleNH
NH
If you know anyone who replaced their Rally rims I'd love to buy one.
Have you looked at https://www.macheforum.com/site/threads/spare-tire-options.20660/ which lists a few options for a spare? If it were me and I was only looking to get a spare, I'd comb the online auto wreckers for a used MME Premium wheel/tire, as it's just a spare and not a normal running wheel/tire and we know that the 19" Premium wheel fits over the bigger brakes. Not all 19" wheels will fit over those brakes. ??
MargaritavilleNH
NH
I will check that out, but a 20 X 8.5inch +45mm offset which will fit a GT should fit my Rally? Just have to pick the GT tire size of 245-45R20.
Thanks for taking the time to respond and share your info.
