Restraint Indicator Lamp Warning
tiebow
Ty
Washington
Mache
My restraint warning lamp keeps coming on and then disappearing and the technician doesn’t know why.
Has anyone have this issue and have it successfully fixed? If so, what was the issue?
I read somewhere that it could be a pinched cord under one of the seats causing this problem but wanting to see if anyone else’s mechanic to successfully fix thi
The technician should be able to read the codes stored in the vehicle and find out why.
Ford Motor Company
Official Ford Account
Ford Motor Company
I'm getting it sporadically, too. She's driving. I'm in the passenger seat. Both buckled up. We drive off, and the light says unrestrained. It seems to do it when I buckled up after she's started the car, and it eventually goes off.
Good morning, Elisa! I would be glad to help you out with these lamp warning concerns if you'd like. Just shoot us a PM with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!
Tangofox
Tomas
Satellite Beach Fl
2022 Mach E premier
Just had this resolved. Was receiving alternating warnings for the driver's and rear safety belts. Scan resulted in code b0050.13. The RCM was removed, tested and reinstalled. Drivers safety belt buckle replaced. Codes were cleared and an Update was installed.
Apparently the update cleared this issue and the intermittent outage of Adaptive and Blue Cruise
E. Shore Farmer
Ben
2022 Mustang Mach e Select
Same thing going on with me. Yesterday it came on at 60 mph, and disconnected the cruise control while in traffic. One pedal drive immediately applied braking; really spooked the guy behind me. Already been to the dealer with it. Guess I’ll be going back.
E. Shore Farmer
Ben
Codes cleared, updates done, and a new drivers side belt mechanism installed. Seems fine now. Dealer was very responsive- perhaps because I shared this thread with him. I suspect there is also some sort of TSB out on it. Interesting, since I think this fault isn’t limited to the Mach e. Only problem I’ve had in 32,000 miles.
