Setting charger schedule
Lowertc
Tom
Connecticut
2022 Mach e AWD
Picking up 2022 MME AWD Premium with 4k miles today here in CT. After reading a number of threads i will be charging most of the times daily. will charger to 85-90% especially in the colder months. My questions is , should I use the onboard(ford Pass) to set the limit and schedule time or use the Juice Box 40 App. if i go with the app would i then need to ensure the onboard is changed if i do public charging(i have one at work and will utilize 1 day a week in the office).
hybrid2bev
2026 Rally
You should set your charging schedule/limits in the car (SYNC screen). Do not set them in FordPass.
The charging schedule is location based so you'll need to charge at each location first for few minutes. Once you set a limit for both home and work that limit won't apply to other locations (will try to charge to 100% everywhere else).
If you have time of use electrical rates at home then I would set the charging times on the Juice Box app as well, just as a backup to be safe.
