herts101
- Peter
- Oct 8, 2023
- UK
- Mach-E 2022
I'm in the UK, with software 4.2.1.2 and can find no way to turn off the speed limit alert or adjust the tolerance to anything greater than 5mph. If I try to do the latter, it just snaps back to 5mph within a few seconds.
As a result, whenever I go more than 5mph over the limit I get a loud beep in the car. If I drop below that and go over again, the beep sounds again. Very very annoying and actually quite distracting.
Having looked at other threads, I have tried the following:
1. Deleted all profiles and recreated them. Still can't turn off the speed alert which won't switch off in any profile, including guest.
2. Done a full reset of the car using the option under General.
3. I had no mykeys set up (confirmed in the settings) but (and not sure of this was related), I did get some off error messages occasionally telling me that my settings might be restricted because of mykey, so I created a new mykey option and then deleted again,
The incessant beeping is driving me mad. Anyone else found a solution to this?
Thank you
Peter.
Thank you
Peter.
