TSB 23-2155 Camera Fix diy help
txaggies07
Aaron
2021 MachE FE Rapid Red
I don’t really want to do this myself but I also don’t want to deal with the dealer on it. I am getting the U3000:49 error that won’t go away and in the history I have the U3000:89 error.
Reading the TSB I believe I need to do the following:
1) step 27 to reset the IPMA
2) back to beginning of TSB and replace the coax cable
To reset the IPMA it looks like I need FDRS. This means I will need to get the mongoose and a 2 day license.
On the coax I have the following questions.
1) How do I determine which cable I need?
  1. LJ8Z-14D202-V (Built With Minor Feature Code HKLAG, HKLAH, And/Or J3QAD)
  2. LJ8Z-14D202-W (Built With Minor Feature Code HKLAF And/Or J3QAA)
  3. LJ8Z-14D202-U
2) does anyone have better routing guides than what is in that TSB. Some of those pictures are hard to tell what they are referring to.
Lastly, am I crazy?
rbertonieresr
Rob
Madisonville, LA USA
2023 Ford Mustang Mach-E
If you’re in Warrenty get the dealer to do it. I printed out the tsb and brought it with me. They kept my car for 11 days mostly due to waiting on one of the parts they needed to change out. When picking it up, the listed work looked like it came right from the tsb. I haven’t had any issues since.
iam-s-Hon
Richard
2021 Job 1 MME Premium AWD ER Iconic Silver, 24 Lightning Lariat AMB
FWIW.. I was having similar errors. Finally dropped it off when I had a chance. Used a diff dealer for first time since they had drop-off/pick-up service. All they did per dx was reprogram the IPMA. No new parts required. So, far have not had an issue since and used BC on a recent work trip for first time in months.
Cost was a few hundred bucks, which I think is less than the quotes to replace the cable, which I had checked the first leg myself and detected no issue.
Good luck.
txaggies07
txaggies07
Aaron
I am out of warranty. If I was still in warranty I would let them have at it.
txaggies07
txaggies07
Aaron
Good luck.
Thanks. I am going to try and do that reset myself with FDRS first and hope I don’t need to replace any cables.
rugedraw
Javier
Miami, FL
Auto Sales
You can reboot the IPMA with FORScan.
360alaska
Josh
Northwest Louisiana
2021 MACH-E RWD, 2019 Model 3, 1997 Ranger 4.0
I made this post, I guess noone saw it:
Here is my post from the other thread:
I did it myself, by my observation, the original front camera cable is in a state of tension, and if you follow each of the cables they are subject to a number of sharp twists. Furthermore, the instructions indicate that only some cars will have the APIM jumper, but near as I can tell they all will since our car doesn't have BC yet still had the jumper. Also, I used split loom cables under the dash.
Here is a photo Dump:
Ford Mustang Mach-E TSB 23-2155 Camera Fix diy help img_6990-jpg-jpg-
Ford Mustang Mach-E TSB 23-2155 Camera Fix diy help img_6987-jpeg-jpg-jpg
Ford Mustang Mach-E TSB 23-2155 Camera Fix diy help img_6993-jpeg-jpg-jpg
Ford Mustang Mach-E TSB 23-2155 Camera Fix diy help img_6992-jpeg-jpg-jpg
Ford Mustang Mach-E TSB 23-2155 Camera Fix diy help img_6988-jpeg-jpg-jpg
Ford Mustang Mach-E TSB 23-2155 Camera Fix diy help img_6986-jpeg-jpg-jpg
360alaska
Josh
Northwest Louisiana
If you get the cables and want some help I'm about a 4 hour drive and will help for a fair donation.
Here's how it went for me:
1.Problem occured, re-calibrate, good for about a month.
2.Problem re-occured, change camera, re-calibrate, good for about a month.
3.Problem re-occured, change cable, re-calibrate, good so far.
txaggies07
txaggies07
Aaron
Thank you so much for this. I had seen some of these pictures on a google search, but when I clicked it it said the thread wasn't there so I couldn't see any of the context.
From your images I have some questions.
1) The purple line in the one that shows the cable routes. Where exactly did you route that? It looks like that is going to the IPMA. If so, where exactly is the IPMA?
2) The orange wire it looks like runs along the ground instead of through the headliner. Would it be possible to run it through the roof and stay out of the A-pillar?
txaggies07
txaggies07
Aaron
If my wife ever takes my kids on vacation with me again I am there.
360alaska
Josh
Northwest Louisiana
#1: this one:
Ford Mustang Mach-E TSB 23-2155 Camera Fix diy help 1727742081744-9
#2 that thought had occurred to me, you probably could, I figure, the reason they don't is due to the glass roof models. But keep in mind you'll need a way to keep the ends together, since normally the A-Pillar connector keeps them connected. You could probably connect the ends and put some heat shrink over them to keep them firmly connected.
txaggies07
txaggies07
Aaron
#1: this one:
Did you replace the connector from the wire to the camera? If so, where did you buy it?
greenaero
Vic
Mansfield Texas
Ford MME gray , Mazda Cx5, Honda CBR250R
Retired Firefighter
@ 360alaska,
How did you get the coaxial cable out of the C900 connector at the A pillar? I have the c900 connector separated but I can't figure how the coax pin end releases from the socket. Any help is greatly appreciated. many thx
