Turning off running daytime lights?
jab
New York
2022 Mustang Mach-E select eAWD
Is there a way to turn on the day time lights without going in to the settings? I usually like to have them on only on cloudy/foggy days so I leave them off otherwise.
Av8tor
Kevin
Richmond, VA
Fusion Hybrid, MME GTPE
Systems Engineer IOT
I do believe if you turn your light switch OFF, they will not turn on.
Nope. The only way to have them turned off while driving is to disable them through the settings menu. Unless you're in a country where they're required by law and can't be disabled (like Canada).
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
Just put your headlights to “Auto”. I personally always turn my headlights “On”, because I want my tail lights illuminated for traffic behind me.
jab
New York
Bummer guess I'll leave them on in the settings and switch the lights to off everytime I don't want them.
Av8tor
Kevin
Richmond, VA
@generaltso is correct, I was wrong.
From the user manual:
The daytime running lamps turn on when all of the following occur:
• You switch the system on.​
• You switch the vehicle on.​
• The transmission is not in park (P) for vehicles with automatic transmissions or you release the parking brake for vehicles with manual transmissions.​
• The lighting control is in the autolamps position.​
• The headlamps are off.​
Note: Other lighting control positions do not turn on the daytime running lamps.
Daytime running lamps are always on unless you switch on the headlamps or your vehicle is in park (P)
They'll still be on.
