joebruin77
- Joe
- Sep 9, 2021
- California
- '22 Mach E GTPE, '23 BMW iX xDrive50
For regular maintenance washes, I would recommend a pH neutral shampoo. I suggest Carpro Reset or Armour Detail Supply Shampoo+ as two excellent examples.So I am ordering the Technicians spray! Question what’s your favourite soap? I’ve gone to two auto stores and just so many. The detailer said low PH no one has a clue. Any suggestions?
If you are going down to your local auto parts store and want something good off the shelf, honestly Meguiars Gold Class Car Shampoo is a great value and is probably in stock.
I am not sure why your detailer would recommend a "low pH" soap, which is an acidic car soap. The only time you would use an acidic car soap is if you were trying to clean mineral deposits or road salt off the car. Car soaps with a pH higher than 7, or alkaline soaps, have stronger cleaning abilities to clean dirt and traffic film. But they also degrade or even strip car waxes and sealants. You would normally use an alkaline soap just prior to applying a wax, sealant, or ceramic coating to get clean, bare paint.
A pH neutral soap is recommended for regular maintenance washes.
