Wheel spacers are on
eec78
Eric
Queen Creek
Mach E GTPE
I am usually one of the "just get a wheel with the correct offset" crowd, but I actually really like the stock wheels, they just need a little more aggressive look IMO. I didn't find much in the forum regarding this so I wanted to share the pics from my results. I went with a 20mm spacer from BONOSS you can find here - subtle change but I love the results.
Before
Ford Mustang Mach-E Wheel spacers are on IMG_5852 (1)
After
Ford Mustang Mach-E Wheel spacers are on IMG_5854
Ford Mustang Mach-E Wheel spacers are on IMG_5865
Panzer948
Charlotte, N.C.
2023 MME GT PE, 2021 Ford Bronco, 2015 BMW M4, CJ5
Geologist
Looks good. Are those factory tires too? Just had to replace mine on my GT PE but went with same spec 20" as I had. I had to make a quick decision after a nail damaged one but part of me regrets that as I would have liked to see what else is out there. Spacers might be a good alternative.
eec78
Eric
Queen Creek
Mach E GTPE
Thank you - yes they are the stock tires as well
Looks more aggressive than stock. I hope that your spacers are hub-centric. The studs are not supposed to support the weight of the vehicle. ??
eec78
Eric
Queen Creek
Mach E GTPE
Looks good!
I have to say, I'm not a fan of the plastic gadget aero-covers on my wheels. I just don't see them holding up well.
What plastic aero-covers are you referring to?
PalsyWalsy
Patrick
Lexus 400H, Lexus 300H, Buick Enclave, Mach E GT
School Administration
Before
After
What wheels are those? They do not look stock/OEM.
PalsyWalsy
Patrick
They are the stock wheels for the GTPE with Nite Pony Pkg
Thanks, could not tell from the pics and forgot about the Night Pony package.
Looks good as I thought about doing the same.
steve.panse
South FL
2022 Mach E GT PE
Looks great. Are there any downsides to the spacers? More chance of stones getting kicked up and hitting side panels or the vehicle behind?
Do you notice any difference in handling from the wider stance?
Panzer948
Charlotte, N.C.
Geologist
Thanks for the quick info. I am very interested in these still so glad you included a link in your first post. Since I didn't go for a new size tire, I may go back and add these. I will warn you though about your tires since I had the same Perillis. As I indicated above, I hit a screw at 18,000 miles and it was too close to the sidewall to recommend patching However, all four tires were nearly warn so it made no sense to only replace one tire. They maybe had a couple thousand miles to go but with a performance oriented AWD car, I didn't want to mix/match so soon just to have that problem going forward.
In a way I am not surprised they only lasted ~20K, as I have a BMW M4 with summer performance tires and they also wear out fast. But... since my wife mostly drives the Mach E, I went with Continental Control Contact Sport SRS+ which are still performance oriented but claim to have a longer tread life. So far, I haven't felt any negatives in handling with this new set.
RKinWA
Seattle, WA
2022 Mach-E GTPE Space White, 2023 Lincoln Corsair Pristine White Metallic
Before
After
Looks better, but seems like unless you have mudflaps it would be kicking up a lot more road grime onto the side now.
eec78
Eric
Queen Creek
Mach E GTPE
Only road grime here is dust so not overly concerned about it ;)
McSquashy
Josh
Massachusetts
Any updated comments or concerns about your wheel spacers?
Instead of going with aftermarket wheels, I ended up purchasing the GTPE rims and had them powder coated gloss black. I love the look of the wheels, but I don't like how they sit too far under the fender. This seems like a great solution! Also, I just installed RB flaps so I'm not worried about road grime.
