Windshield washer freeze up
Vnorvi
Vern
Evergreen CO
2023 Mach e performance edition
Attorney
I live in the mountains in Colorado and. Needless to say it gets cold. I use -50 washer fluid, but the other day the washers stopped working on the way to the ski slopes. It was 8f. I assume the washer pipes freeze more easily since there is not an motor around. Any ideas or fixes? It is not a huge deal since they started working again as soon as the sun was out for a while.
YunniorO
Jacob
Westminster, Colorado
2021 Mach-E Premium AWD (Job 1)
I live in Colorado and have driven my MME in below 0 temps but never had this issue. What brand of fluid are you using? I use Peak in mine.
Make sure you flush fluid through the system regularly (both front and rear washers). If the fluid sits in the lines for weeks the methanol will evaporate and you’ll lose the freezing point protection.
Dealers sometimes refill with non protected fluid during service, so that could be a factor too.
Phrozen
Henry
Fairbanks, AK
2022 Grabber Blue Mach-E
Don't dilute your fluid in winter.
tuminatr
Saint Paul,MN
2021 MME GTPE
sales
The solution to this is get it in a heated garage, thaw the lines and replace the fluid.
Never had it happen to my Mach E but I have had it happened to other vehicles I've owned. Mainly it was a service department adding fluid. Maybe not realizing that it what they put in isn't good for the cold temperatures.
Space_Pony
Indiana
2026 Premium Mach-E eawd
How do you replace the fluid?
tuminatr
Saint Paul,MN
2021 MME GTPE
sales
Once it's thawed out just run the system like normal. Typically shops will either pump out the old fluid in the reservoir or just run the system dry to make sure all the fluid gets replaced.
Space_Pony
Indiana
Umm, use it up and pour more in?
I think a vacuum pump that I have would work better. I've never had that problem. I always run straight washer fluid.
tuminatr
Saint Paul,MN
2021 MME GTPE
sales
Living in Minnesota this is common every winter. It's happened to me and I use fluid that is good to -45.
Yes use a vacuum pump to clean out the reservoir. Replace the fluid, then run the system a little bit to make sure the lines have new fluid in them. Vacuum pump typically won't get the fluid out of the lines, only the reservoir.
Vnorvi
Vnorvi
Vern
Evergreen CO
Attorney
Thx
Alutacon
MD
Mach E GT Perf
Didn't know there was a rear washer. How do you activate it?
