Workaround for the Tone Setting Bug
dml105
Arlington, VA
I think I’ve got a workaround for the bug where the sound settings for tone get reset when you turn off the car. I think it’s related to the profiles.
If you go into your settings and momentarily turn off profiles. Then set the tone to your desired settings. Then go back into the profiles and turn on your profile again. Set the tone to your desired setting (if it isn’t already set).
And voila. In my Mach-e, the tone is now set permanently.
Eraser
2021 Mach-E Premium RWD | SR
In essence it sounds like this would simply change the default tone settings to match your profile. Although the issue still exists, it would at least have the desired effect of loading the correct tone settings. Good idea, I'll give this a try and will report back.
Eraser
Worked flawlessly, great find. That has been a major pain in the ass for quite a while. Thanks for the post ??
dml105
dml105
Arlington, VA
Fantastic!!!
I tried it when I noticed that the bug showing up when i turned off profiles.
MarkP213
Mach E 4X Premium, Infinite Blue
Thank you for this! Works perfectly!
Deleted member 4669
Guest
Thank you! This was driving me nuts but your directions Worked.
Infinite_Jester
Eric
Atlanta
2021 MME, 2011 Chevy Suburban, 1966 Caddy
Thank you (1) OP and (2) search function cause this was driving me batty!
Tyldum
Norway
Mustang Mach E First Edition
This problem in affecting many settings. I found it best to use the numbered buttons on the driver's door to switch profiles quickly every time I enter the car...
