Pioneer74
- Feb 24, 2022
- Dearborn
- 2022 Lightning Lariat ER - 2022 Mach-E Premium
This is easy. Use green phase tape on the neutral at both ends to designate it as a ground. Land it on the ground lug on the receptacle and move it to the ground bar in the service panel.The 10 series has two hots and a neutral. Most EVSEs need two hots and a ground. Many electrical boxes bond the neutral to ground, but you would need a qualified electrician to look at the circuit to ensure that the neutral can be used as a ground.
