Deleted member 3569
Guest
I am interested to know from those who have swapped the OEM 12v LVB (BHAGM-H3 380CCA/35 Ah) with AC Delco's LN1AGM (520 CCA/50Ah), specifically if it improved or mitigated the 12 Volt Battery Fault - Service Soon pop ups on the iCP... and whether the negative post cable (Battery Management System part LJ97Z10C679A $76.28) needed to be changed as well ??? ... is it really necessary to replace this part every time you swap the 12v battery?
I have also noticed that the connector lead to the BMS is short and won't reach the negative post of the AC Delco's LN1AGM... most likely I will need to splice a short length of wiring.
The reason why I am contemplating to change the original battery is that I have put a smart charger on the battery that came with car for about 72 hrs and saw the charger go thru different charging cycles ... after this charging my 12v pop ups that used to flash had effectively vanished.
I had take the car to the dealer for the 12v Battery Fault and they did: EEC test, battery test, cleared codes, re-set BSC, etc... after this the pop up only flashed sporadically... but it was still there. After charging the 12v battery for 72 hrs the were no more pop us.
