2025 Mach-E in possession less than 2 days and 12v battery issues
N1naz
N1naz
George
New Hampshire
2023 Mach-E BD-23/Sep/2023
That sucks, but likely once the new BECM is installed everything will be fine. It's good that they found the problem and that Ford has a replacement on the way. Hopefully the loaner is a nice car.
Loaner is another Mach-E, don't know what year yet, picking it up later.
Hi All
Wife had her car now for two days and the 12v battery is already down to 11.5v 45%, will not charge and displays “pull over and get out of car safely” also battery icon showing in red on display. Luckly its in our driveway, will not go into Drive. Being towed to the dealer/service. Has charging error when plugged in. Yes, we had it plugged in overnight and when we looked this morning Ford Pass showed charging error, went out to unplug and plug back in same thing. :mad:(n)?
Didn't do an error code check while I had the obd plugged in so dont know if there are any errors codes.
George
You got one with SIDS... :(
Ahlarict
B.L.M.
Greater Cascadian Megalopolis
2024.5 60th Anniversary MME Rally Edition - "Shadowfax"
International Man of Mystery
Seems kinda crazy, but the very existence of this goofy "battery sync protocol" kinda proves that Ford implemented some dumb static logic about when to charge the 12v system based off every kind of nonsense except the battery's actual current voltage! I assume they had their reasons, but this is the direct and obvious cause of a lot of MMEs with dead 12vs that have fully charged HV batteries with fully functional onboard chargers that were never turned on in time... Control Theory 101.
  • Like
Reactions: TWD
Seems kinda craxy, but the very existence of this goofy "battery sync protocol" kinda proves that Ford implemented some dumb static logic about when to charge the 12v system based off every kind of nonsense except the battery's actual current voltage! I assume they had their reasons, but this is the direct and obvious cause of a lot of MMEs with dead 12vs that have fully charged HV batteries and fully functional onboard chargers that were never turned on in time...
The problem with OP is there is a high voltage fault, so the 12V battery can't recharge since the high voltage battery is effectively shut down. It's not a BMS issue. If the high voltage system was working, then the 12V would be recharging itself.
Ahlarict
B.L.M.
Like a hypoxic brain, an MME's onboard computer can have all manner of sensory hallucinations when operating on low 12v voltage... Charge the 12v, then see what's what.
DonM
Don
I have TWO 2024 Premium AWD Long Range Mach-E's: One Eruption Green, one White
Ahlarict
B.L.M.
hack-e
Austin, TX
2022 Prem AWD ER MME
Robotics Engineer
MoonRiver
Tampa Bay, FL
22 Mach e select, 07 Infiniti G35
I went back to L1 recently. Unless I need a fast charging I'll stay with L1.
Herbknowsit
Herb
2024 Mach E Select AWD Ext battery-Comfort Package. Eruption Green
Retired after too many years traipsing the globe for a paycheck
Text 734-892-0892. They can pull the 12v SOC and voltage
Is that number direct to Ford or what? Maybe I missed this in other threads?
I’m guessing it’s one of those phone lines that Poodles don’t call. ?‍♂?
EB87
2024 Mach-E Premium
Yes it’s too ford they can provide 12v battery SOC and voltage info as well as answering other basic general questions about the car. I only occasionally reach out about my 12v battery as I don’t really have any other questions.
  • Like
Reactions: TWD
Ahlarict
B.L.M.
My Uniden R8 radar detector (tapped into the mirror's wiring harness) has an option to constantly display the 12v system's current voltage which is nice. I've never seen it dip below 13.1v in operation yet, and you can see when the DC charger is operating as the voltage jumps to around 14.5v.
N1naz
N1naz
George
New Hampshire
