24-PU0105-CMR-FX
hack-e
Austin, TX
2022 Prem AWD ER MME
Robotics Engineer
After the update finished, the only (now regular) odd thing I noticed was that I had to turn off the ask on exit for the alarm system. I drove it around and tested hands-on and hands-off assisted driving and everything seems fine so far.
FastEV
Kansas City
2023.5 Mach-E GT PE
This is awesome news!
If someone applies this CMR module update manually via FDRS, could you post details about the module software version? If we can verify that the update is available in FDRS, I may manually apply it instead of waiting for it via OTA.
rugedraw
Javier
Miami, FL
Auto Sales
PTS is showing a CMR update available for you. Remind me later to check in FDRS to confirm for you.
Ford Mustang Mach-E 24-PU0105-CMR-FX 1708697143452
mccdeuce
Millersville, MD
2019 VW e-Golf, 2022 MME Cal RT1 IBSM
Waiting for someone with broken BlueCruise like me to say this update fixed the driver facing camera. ?
I have the broken BC and the update has so far failed. Not sure if it can’t over write the stuck image that caused BC to fail or not. Hopefully will go through tonight and will let you know.
HoosierMachE
Indiana
2023 Mustang Mach-E GT
Thanks for letting me know! According to OP, Ford requires a 50 minute inhibit, in addition to a bunch of preconditions. Hopefully it goes through for you tonight. I usually get OTAs pretty early, but haven't seen this one yet. Good luck.
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51, 2024 Emira
Why don't you install immediately? You will have a better chance of successful install.
rugedraw
Javier
Miami, FL
Auto Sales
Most likely failed due to low battery conditions. Throw a charger on your LWB or try one of Mach-Lee's charging methods:
https://www.macheforum.com/site/threads/how-to-get-failed-otas-to-install.29749/
It won't take that long based on reports from people who've had it go through.
mccdeuce
Millersville, MD
Normally how I do most updates. Unfortunately, it’s greyed out.
LVB is currently at 80% so hoping as it stays on charge today/tonight it will go through. I am hoping when it first attempted LvB was low which is why it failed and not because it can’t overwrite whatever is causing Bc to fail.
rugedraw
Javier
Miami, FL
Auto Sales
I can check with your VIN. PM if you prefer to keep it private.
Edit: In your case, it failed due to a manifest mismatch. The OTA process never progressed far enough along to where your car reported the battery stats to the cloud.
metfoo
Bay Area CA
2021 Grabber Blue FE
I have been waiting for this update since December. Long story short, my first edition had a failing 12v battery. They replaced it as well as the battery control module and the gateway module. This broke my phone as a key and connectivity. Per my advisor, ford rewrote the gateway module software, and they were awaiting the new update from Ford.
Last night, after I updated, I tried to setup PaaK, and it failed. Today, I tried again and it worked. Now my app is finally working again, and I have the long overdue, working, frunk button.
This update made my weekend.
Yup, read his post. My LVB is usually hovering around 80-95% (obd confirmed) at all times. Going to just wait it out a couple days to see what happens, I guess...
Watch for an opportunity to “Update Now”. Drive the car, plug it into an L2 charger, turn off the headlights and update now. That usually works for me.
hack-e
Austin, TX
Robotics Engineer
I just discovered that I think this update unlinked my phone to my profile.
I noticed because I remote conditioned the car today and it was on the guest profile when I got in the car. That is a signal to me that the phone might be unlinked to my profile, as a previous update last year did the same thing except that it took me weeks to realize it wasn't the guest profile but rather just an update that unlinked the phone. And when I checked this time it indeed was unlinked.
It was easy to link again.
It also changed my radio to a random AM station. Also an easy fix.
