a question for change tire on Mach E
epec
Wensen
Houston, TX
2019 Ford F150, 2022 Ford MME
Glad my original tire on my 2022 select RD last until 43k miles and it is time to replace them. ordered the matching tires from walmart but when I went there for installation, they told me they can not install the tire on Mach E as they need a "block" so they can jack it up without damage the battery. Called Costco and Discount tire and confirmed they can install mach E tires . Question here, since not all the place can jack up Mach E, is there any place on line I can buy those "block" so if something happen to the tire on the road, I can go anywhere to fix them if I carry those "blocks " with me .
EMachE
Enzo
YEG
Mach E, Escape Hybrid
Mechanic
There are arrows that show you where you can lift your MachE just under the rocker panel and all you really need are the hard hockey pucks. I have the after market pucks but seldom use them. Basically lift where the bolts are.
BobCz888
Robert
25 Hidden Hills Dr, Seaford, DE, 19973, US
Mach E, F-150, Lincoln LS
Amazon https://a.co/d/eeBAXUS
GreaseMonkey
Chicago, IL
24 Mach-E GT
@epec I prefer these blocks. Very expensive, but are very easy to use as they don’t create a blind lift situation. The box them come with packages well near the mobile charger in the trunk’s underfloor.
https://a.co/d/eM5VdlI
Game mach e GT
Minnesota
2023 Mach e GT
I bought some at Amazon $25
