AA Wireless Connection Failed.
Chicago
Mach-e Gt
My andriod auto keeps failing/disconnecting on my 2023 GT. I'm on update 6.13.0. I have tried to reset sync and Bluetooth/wifi but sometimes, it works for a bit then fails or fails to connect at all. I'm can still see that my phone is still connected since I have access to the recent contact screen, so I have to either resync with foward/down buttons or go directly to andriod autothrough the menus. I have a Samsung 23 Ultra with updated software and on andriod auto. AA was working fine for a few months with occasional disconnection here and there but they're frequent now after the update? Or maybe Spotify or maps is messing it up. I will still need to test it without Spotify playing since I mainly use AA for music and Google maps. I have read all the topics in this forum and I tried all the methods but I still don't have a fix for this and worse case is that I transition to USB. If anyone could help me or direct me to a topic / forum that I've missed, that will be much appreciated. Ty!
Ford Motor Company
Official Ford Account
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
GrayWolf
Brent
Atlanta, GA area
2021 Mach-E GT (Star White Metallic)
This is a problem with the S23 Ultra and not your car. I have both the S23 Ultra and a Pixel 8 Pro. The S23U is guaranteed to be a bad time in the car for AA Wireless. It will not work on wireless with any reliability due to some bug introduced in the One UI 6 release (none of the updates since release have corrected this).
The Pixel 8 Pro, by comparison, is 100% solid on AA Wireless in my experience.
So, for now, my S23U is resting in a drawer until I see some news that Samsung has "woken up" and fixed their "flagship" device. Ugh.
Reddit has several threads on the One UI 6 breaking AA Wireless now, so there is hope for this to be fixed... some day.
Here's an example, for your reference:
AA Not Automatically Connecting After One UI 6.0 Update : AndroidAuto (reddit.com)
If you want to save yourself a headache, turn off the "Wireless Projection" function under the Connectivity section of the settings menu. This will force the car to only accept USB-connected AA connections. If you do not disable the setting, AA will reconfigure itself silently to work wirelessly and then lead to another, random/spontaneous, failure.
Orangedepressed
Chicago
Mach-e Gt
Sad times. At least its a phone issue and it was working fine until recently.
TYTY! for the response, I might as well use USB-Connection until they / S23U fixes itself.
Johnjr08
El Mirage, AZ
2021 Mustang Mach E Premium Ext Range AWD
Same issue here with a Oneplus Open. It was fine with my Pixel 6 Pro, but with the Oneplus Open it works most of the time, but will disconnect randomly.
I've noticed if I plug the phone into a charger (using a cigarette plug adapter), then it almost always disconnects from AA wireless within 30 seconds. Not sure what the issue is, but it's the phone for sure, not the car.
Anwarlucas
Anwar
Minnesota
2023 Mach E GT
I have the OnePlus open, if I don't get the failed connection at least 2x a day I'll be surprised, for me it started after the 6.13 update and the few random ones including the am station update as well.. prior to these update, I never had this issue..
