Anyone else have issues with update 6.14.0?
2023 Ford Mustang Mach E RWD Premium
23 premium RWD
Ever since the update:
  • Driver's window doesn't go up unless all the way down - if the window is half way down pressing the up button rolls it down. Holding the up button rolls it all the way down. Pressing the up button again rolls it all the way up.
  • Blue cruise doesn't stay active - it turns on and immediately turns off and says hands free ready and goes through this endless cycle.
  • Lane keeping assist is erratic and acts drunk - it no longer nudges the car over from the side of the lane. After the update it makes a hard jerk into the center and over corrects and hits the other side and bounces back and forth like a pinball until lane keep assist is turned off.
It should be noted I have updates set to install at 1am whenever available. This happened while I was driving at 6pm not during my schedule. The screen jittered, flashed then shut off before it restarted. Immediately I noticed the above issues and it's been a week with no change. A week prior I received the vague update that stated my vehicle is being prepared for future updates.
Also the new silhouette icons are atrocious. They look like 2005. I prefer the HD images.
23 premium RWD
Your schedule is for applying updates that require immobility, not for applying all updates.
The screen rebooting had nothing to do with updates and everything to do with an issue that the vehicles have that is supposed to be fixed in Q4.
Are you saying the screen reboot and the update are unrelated but coincidentally happened simultaneously? Because this is the only time the screen has ever rebooted.
AtomicInternet
SC
Focus RS, Mach E Premium
6.14 was largely a cosmetic / infotainment update. I suspect the latest IPMA update would help you with your bluecruise/lane keeping issues. If you have access to FDRS or someone with it (or just ask your dealer to run the update) it may help.
Then again, you might have configuration issues if you can check with Forscan
Would there be any reason for a cosmetic update to trigger multiple system failures seemingly unrelated to the update?
AtomicInternet
SC
As mentioned, if you have Forscan you can check if it possibly reset some configuration settings inadvertently. That's the only possible way I can see it would affect the other modules.
AtomicInternet
SC
thenew3
Central Coast CA
BMW X7, BMW X3, MME Premium 4X
The only issue I have with 6.14 is now the backup camera wide angle/pano view takes about 30 seconds to start after you click the button. Very annoying.
rugedraw
Javier
Miami, FL
Auto Sales
That is FDRS, and indicates your module software versions.
FORScan displays your module configuration settings
I know some (not me) owners in that thread can remotely check your configuration settings if you ask.
Just checked his config for BC on the APIM and IPMA and it looks perfectly in-line for his version of BC. His car is not reporting any codes that it wasn't reporting before the update.
Yes, stranger things have happened. In your case, whatever is causing BC not to work is not obvious. Not to me, anyway. OTA history shows you got 3 updates in a week: 24.2.4.9, 24.2.4.9.1 and then 6.14 a week ago.
Ford Mustang Mach-E Anyone else have issues with update 6.14.0? 1719954781478-d3
phil
LS400
30 seconds sounds too long. Is that for everyone with 6.14 and later, or is it just you?
