Auto Climate Vents
raijinmach
Ottawa
n/a
When I set my climate to auto, only the dash's vents are working. Is this intentional? When I set it to manual, it comes out of the desired vents just fine.
tbrumleve
Tom
Oregon, USA
If I turn up the temp in auto, it blows out the bottom vents. It’s “auto” so it should automatically decide which vents are appropriate.
AUTO chooses the correct vents based on the heating or cooling demands.
  • If heat is needed, floor and/or defrost vents are used.
  • If cooling is needed, panel vents are used.
So if it was hot in your car and the A/C was running, then there won't be air coming out of the floor vents because that wouldn't be as effective as using the panel vents. I recommend you stick with the AUTO setting for maximum effectiveness and efficiency.
Chapron
Detlef
germany
Mach e RWD EX TP2 / 2023.75
SAP Engineer
With some ota there was a change in the Ventilation auto setting. After that ota which i can Not Identity which it caused that there is even on setting 2 of 3 only a little air. Its almost as it was in the past when i was at a phone call. But then after i hung up it would come back again stronger. May be one of you have that too?
Blower speed will decrease when the microphone is active. That’s intended behavior.
Chapron
Detlef
germany
SAP Engineer
Yes i meant that it happens even when i am not on the phone. As I wozld be but I dont.
