Matstar
- Feb 2, 2022
- Canada
- Mach E Premium
Little test today to see the preconditioning with GPS behavior at low temperature.
Unfortunately it was not a success.
Cabin already hot at 20C (68F)fan on auto 1. At highway speed, outside temperature -5C (23F), battery temperature between -1C and 5C (30F to 41F).
I enter a nearby fast charger into the GPS to start preconditioning. The coolant does not rise in temperature to warm the battery. I turn off the cabin heating and suddenly the temperature of the coolant starts to rise. I restart the cabin heating, the coolant temperature drops immediately. So unable to heat battery and just keep the heat in a already heated cabin.
In conclusion, the reduced power capacity of the Mach E heating system does not allow you to take advantage of the preconditioning during a road trip. And this when it’s most important… when it’s cold.
Maximum charging speed of 42Kw on a 350Kw charger.
Well done Ford
Well done Ford
