Bluecruise eye tracking - does it cause headaches
Only if you believe airplane contrails are actually chemtrails, otherwise, you’re all good ??
Oh, don’t forget about the microchips in vaccines. If you’re concerned about microchips in vaccines then, please tape over the BlueCruise eye tracker right away. Also, tape over the FaceID scanner on your iPhone.
If the strobing BlueCruise eye scanners are causing headaches, or the buzzing from the eye scanner assembly is interfering with your ability to hear conversations in the vehicle, I recommend you just stop by the tin foil hat store and have them adjust your hat to make sure it’s effectively blocking out all the mind control signals from the internet ?
NoVAguy
None
Also, you can't forget about the fact that 5G towers are causing the coronavirus!
I’m good. I stocked up on ivermectin at the vet and hydroxychloroquine when I said I had malaria. ?
Ride_the_lightning
Midwest
Mach E Premium SR AWD
BlueCruise is not level 5 self driving. You will still get a DUI. The headache is from the drinking you did before getting in the car.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
I have not gotten a headache from eye tracking. But I have gotten a headache from being told to “watch the road” continuously while I’m watching the road.
Valkyrja
United States
2021 Mach-e GTPE, Star White
I hack things
Been driving the MME for a week now and really like the Blue Cruise but I am wondering if the strobe lights use to track your eyes might cause headaches. I cannot find a thread about it. But I do think some owners have covered the bar up.
As others have pointed out, it would not be likely for a number of reasons. However, as a cluster headache sufferer (they are nicknamed suicide headaches), vibration may be a cause. I would empty the car out as much as possible and start noting when the headaches set in. Note time, temp, and road surface. Double check your tire pressure, basically anything that can impact the ride.
Hope you can figure out the trigger.
But, but chemtrails are real! We had to arm or manually activate them all the time enroute! I took pictures as proof. :p
Ford Mustang Mach-E Bluecruise eye tracking - does it cause headaches 1667105845025
Ford Mustang Mach-E Bluecruise eye tracking - does it cause headaches 1667106045071
