Can someone more knowledgeable inform me
2023mach
Nicholas
New york
2023.5 MachE Premium Extended AWD
I recently read that you shouldn't charge above 80% while DC fast charging ( i never level 3 charge ) I've only had the Mach-E for about 2 weeks. I charge for free at work! -- Should/can i be charging to 100% on the level 2 charger at work? So far i have not charged above 80% at work. the charger at work is 5KW charge rate if that helps info wise.
hybrid2bev
2026 Rally
It's not that you "shouldn't" charge above 80% when doing DCFC. It's just that the charge rate slows down considerably above 80%, so you're probably better off time wise to just stop and move on to the next segment of your trip (next charger down the road).
Do you NEED to charge to 100%? If not, then try to be in the 80-20 range for best long term battery health. I charge twice a week to 90% at work. It's free and I know that I'm going to be driving home, which will run the battery down by 10%-15% depending on the season, so I'll spend most of my time in the 80-20 range.
Bottom line: charge to what you need to get you around. Knowing that being closer to 50% is better long term than being closer to 100% or 0%.
2023mach
Nicholas
New york
Ford recommends limiting it to 90% for daily level 2 charging.
You can charge above 80% at a DCFC, but the rate slows way down, so it will take a while. And if the station charges per minute, it can get expensive.
Thanks -- i was unable to find the recommended limit so i appreciate the info. I will schedule my level 2 work charger to stop at 90%
The important thing to remember is that extended time at either end of the charge level spectrum (low or high) is what accelerates battery wear. If you are going on a long trip and your first charge stop requires you to use 90% of your battery capacity, go ahead and charge to 100%. It’s not going to dwell that long at 100% of usable capacity for that long. Likewise, if you need to “drain” it to 2-3% to make a charge station, go ahead (just drive judiciously). ??
ReverendPete
Pete
Denver, CO
2023 MME Premium, 2018 Toyota Highlander Hybrid
Software Developer
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
If I could charge at work, I would charge to 100%, and arrive at home at under 85%. Then I would charge to 90% at home overnight, and rinse and repeat. Because free charging!
