Charger efficiency question
MonorailGrey
Rob
New England
21 Premium AWD standard range
I’ve been charging solely level 1 at home since I bought my standard range premium AWD a few months ago. Given the small amount of driving I’m doing, I’ve never had an issue with not having enough range. I started using a kill-a-watt to track how much power is being consumed and found that the car is using more power than I expected.
For instance, in a recent week I drove 89 miles and the trip computer reported 2.7 miles per kWh implying the car used approximately 33 kWh. The kill-a-watt reported that I actually used 53 kWh.
Is this kind of power loss in the charger expected? If I was to install a level 2 EVSE, would this improve?
Thanks!
OWG
MA
2025 MME GT
Thanks!
Losses occur at every transition. I wish DoE were further along with the Energy Star standards ( ENERGY STAR Version 1.1 EVSE Certification Webinar Slides - April 8, 2021 ) and that manufacturers efficiency data were a little more transparent. But there is an Energy Star comparator ENERGY STAR Certified Electric Vehicle Chargers | EPA ENERGY STAR .
According to the US Department of Energy’s Office of Energy Efficiency and Renewable Energy, “EVs convert about 59%–62% of the electrical energy from the grid to power at the wheels.
Electric Car Myth Buster — Efficiency - CleanTechnica
On average, Level 2 charging was 5.6% more efficient than Level 1 (89.4% vs. 83.8%). In those charges in which the battery took up less than 4 kWh, this difference in efficiency was even greater: 87.2% for Level 2 vs. 74.2% for Level 1.
A comparison of electric vehicle Level 1 and Level 2 charging efficiency | IEEE Conference Publication | IEEE Xplore
Using the trip computer is inexact at best. 89 miles driven includes electricity regenerated by the car.
What you want to do is to plug the car in after resetting the Kill-O-Watt, and when it's done charging look at the FordPass app and it will tell you (I believe it says "Details") on the bottom of the screen how many kWh it used in that charging session. Compare that number to the number that the Kill-O-Watt says. You should lose about 15% at most.
timbop
You can expect about a 10% to 15% loss due to heat and inverter inefficiencies. You're seeing more than that, so the next question is if you also precondition (with departure times) or warm up the car at all on shore power?
Polar
SBJ
PNW
2021 Select RWD SR
Yes, a lvl 2 EVSE would be far more efficient.
nvabill
Virginia Beach, Va.
F-150, '22 California Route 1
Thanks!
Following.
nvabill
Virginia Beach, Va.
Simply click the “Watch this thread” box below.
I'm aware of that function, was just showing Rob I am interested in his topic. And before you tell me to hit the like button, yes, I am aware of that also. ?
OWG
MA
2025 MME GT
Well, I am guilty of having made an uninformed comment.
DoE's site provides a wealth of information on EVSE's. The dataset has the following as headings:
ENERGY STAR Unique ID
ENERGY STAR Partner
Brand Name
Model Name
Model Number
Additional Model Information
UPC
Product Type
Max Nameplate Output Current (A)
Input Voltage (V)
Number of Outputs
Maximum Output Cord Length (ft.)
Output Cord Gauge (AWG)
Screen Area, if EVSE has high res display (in2)
Maximum (100%) Measured Luminance of the High Res Display
Automatic Brightness Control (ABC) Capable?
Connected Functionality Capable?
Connected Functionality Capabilities Summary
Communication Standard - Application Layer
Protocols Used to Support Smart Charging
Product Features
Network Protocol with Wake Capability
No Vehicle Mode Input Power (W)
No Vehicle Mode Total Allowance (W)
No Vehicle Mode Power Factor
Partial On Mode Input Power (W)
Partial On Mode Requirement (W)
Partial On Mode Power Factor
Idle Mode Input Power (W)
Idle Mode Requirement (W)
Idle Mode Power Factor
Full Current Operation Mode Test: Calculated Efficiency
Full Current Operation Mode Test: Total Loss (W)
30 A Operation Mode Test: Calculated Efficiency
30 A Operation Mode Test: Total Loss (W)
15 A Operation Mode Test: Calculated Efficiency
15 A Operation Mode Test: Total Loss (W)
4 A Operation Mode Test: Calculated Efficiency
4 A Operation Mode Test: Total Loss (W)
Dual Input Level 2: No Vehicle Mode Input Power (W)
Dual Input No Vehicle Mode Requirement (W)
Dual Input Level 2: No Vehicle Mode Power Factor
Dual Input Level 2: Partial On Mode Input Power (W)
Dual Input Partial On Mode Total Requirement (W)
Dual Input Level 2: Partial On Mode Power Factor
Dual Input Level 2: Idle Mode Input Power (W)
Dual Input Idle Mode Requirement (W)
Dual Input Level 2: Idle Mode Power Factor
Dual Input Level 2: Full Current Operation Mode Test: Calculated Efficiency
Dual Input Level 2: Full Current Operation Mode Test: Total Loss (W)
Dual Input Level 2: 30 A Operation Mode Test: Calculated Efficiency
Dual Input Level 2: 30 A Operation Mode Test: Total Loss (W)
Dual Input Level 2: 15 A Operation Mode Test: Calculated Efficiency
Dual Input Level 2: 15 A Operation Mode Test: Total Loss (W)
Dual Input Level 2: 4 A Operation Mode Test: Calculated Efficiency
Dual Input Level 2: 4 A Operation Mode Test: Total Loss (W)
Date Available on Market
Date Certified
Markets
CB Model Identifier
Lots of unpopulated columns - Data definitions here: Electric Vehicle Supply Equipment (EVSE) Key Product Criteria | Products | ENERGY STAR
