Charger Fault !! Please Help
MajsterkoV
Bartek
Poland
MME 21 Premium Iced Blue , MME 23 select Vapor Blue Me , Explorer ST 25
I bought charger from Ali for 230v beacuse i needet to charge car while searching for parts ( its from us, bought it little damage ) . After pluging it for first time it was charging for 20minutes no problem now when i plug its charges for 2 seconds and says charger fault same with Ford oem wall charger that i wanted to try with type 1 adapter beacuse its european one. ANY IDEAS WHAT CAN CAUSE THAT ?
As you're in Poland, not many people are going to be able to comment. Where you bought a charger from is irrelevant, what make and model it is, and if it is compatible with your wiring and electrical system, is relevant.
MajsterkoV
MajsterkoV
Bartek
Poland
ITS a Andaiic 16a 1phase type 1 charger that ford oem one is 1 phase type 2 but im using adapter and it doesn work
MajsterkoV
MajsterkoV
Bartek
Poland
Dont really know waht u mean by is it compatible with your wiring and electrical system . Us made mach e comes with other plug only or is it something else
I know nothing about European car charging, and few do here. You have a US-market Mach-E that you then exported to Poland (versus a model made for a European market), so you have a US J-1772 port and a US CCS1 port, vs. a European CCS2 port?
MajsterkoV
MajsterkoV
Bartek
Poland
Yeup and im using chinease charger with type 1 connection ( us one) and i have european ford wall charger with adapter
MajsterkoV
MajsterkoV
Bartek
Poland
The tning is that that chineese charger was charging for 20minutes and now i cant chargr eaven with oem one
