Charging Error/ Electrical Drain System Service
SD Dylan
Dylan
San diego
2024 mach e
Sales
Hello,
I bought my wife a 2024 select rwd standard battery and has 2800 miles on it now. I got myself a 2023 select rwd standard battery that has 8000 miles on it. We've had her mach e for a 3 months and mine for a less than 3 weeks now. We got the Ford Pro charger installed at our house.
We usually plug one of the MME's in every couple days to charge when we get home for work (about 5pm). We have both cars set to charge from 12am to 6am in the ford pass app(best rated with electric company). The wifes MME has occasionally has the charging error come up we unplug it for a few minutes and plug it and it charges properly.
Friday when we plugged mine it it said charging error. I unplugged and plugged back in a couple minutes later it showed waiting to charge at 12am. We went to sleep and woke up and it didn't charge. We unplugged and plugged back in and started the charge at that time.
Fast forward to last night. We plugged in and it said waiting to charge at 8pm and then switched to 12am. Then a few minutes later got the charging error message. I unplugged. We logged out of the ford pass and logged back in and plugged it back in and made sure the ford pass app was up to date.
It showed waiting to charge. We went to sleep my wife woke up at midnight and checked if it was charging. There was a charging error at 11:45pm over 2 hours from the last time we plugged in. She started the charge then and it charged last night.
This morning I had Electrical Drain System Service notfication. I drove the car to work. Still at work now. Not sure if I should be concerned about that electrical drain notification.
How do I stop the charging errors from happenning?
Lonesparrow67
Boston, MA
2024 Premium MachE-4X
This might not solve your issue, but I had issues in the past with the FordPass app showing the wrong times causing charging issues...
What I did was delete the schedule from the FordPass app, then create a new schedule in the SYNC software directly in the car instead...
Once done, the FordPass app showed the new schedule correctly, and I have since not had any issues....
Maybe worth a try? ?‍♂
