Charging problem, then SVS message, then resolved on its own
RMoore
Rob
I had an odd experience (for me at least) today. I drove to work, plugged into one of the chargers there as I usually do--a Tesla L2 charger with a J1772 cable (I think that's the right #), and walked into my building. I looked at the FP app and noticed it wasn't charging--it said I should check it and unplug and then plug it back in. I went back to the car and saw that the lights on the port were all red. I unplugged, waited a few seconds and plugged back in but still red and not charging. I did that a few times with the same result each time, and then unplugged and put the cable back in the EVSE. I went to start the car to move it out of the spot and got the SVS message. I then tried to shift to R but it was locked in park. I had a meeting I had to get to so went to that, then came back a few hours later and was able to start the car. No SVS message and I was able to drive it.
When I got back home I was able to charge with my ChargePoint EVSE. I did notice though that the FP app doesn't seem to show the charging rate anymore--is that new, or is it because it I told it to charge to 100% (I have it set to charge after 9PM)? The ChargePoint app shows I am charging at 10.82kW as is typical I think.
I don't have an OBD reader, but would it be helpful to see the error codes from one? I could always order one. I can't recall--is this something that can be checked by folks here if they have my VIN or do I need to hook up an OBD reader?
RMoore
Rob
Addendum re FP app not showing charging rate: looks like this is an oddity of "charge to 100%" since I just plugged in, it started charging per my schedule, and it does show a charge rate of 10kW.
Would love some input on whether I need to worry about the charge fault and SVS message if things seem to be working ok now (other than failed 4.2.6 install as others have written about).
RMoore
Rob
So you had a charge fault and needed to do a HV reset. Didn't work till you came back because you didn't wait long enough. See here: https://www.macheforum.com/site/thr...ng-service-vehicle-soon-while-charging.26983/
And there is a bug in FordPass where it won't show the charging power after pressing the 100% button. So that's normal.
Thanks, this is very helpful and reassuring. I guess I missed that thread. Looks like I went through the reset procedure just by leaving my car for a few hours. I might just avoid that particular EVSE though it is one of the few with a J1772.
