Charging
0144kop
Conal
Cf381ax
Mach e awd er
Auto electrician
Just bought a mach e AWD ER with 6k on clock,picked it up from dealer with 100% 189 miles,got it home and then charged it back up to 100% 195 miles, is this normal for the Extended range model.
kkriskal
KK
Colorado
2023 Mach E GT Cyber Orange
The range fluctuates based on several conditions like your driving habit, temperature outside, elevation driving etc. First step, reset the EV driving history so it gets reset and adapts to your driving habit. Then it will keep fluctuating based on temps as well.
0144kop
Conal
Cf381ax
Mach e awd er
Auto electrician
Thanks for that ,where do I reset the ev to as I just got the car
You'll want to reset everything with a master reset. You can find the owner's manual at owner.ford.com.
Going forward, you should charge to 90% unless leaving on a trip.
0144kop
Conal
Cf381ax
Mach e awd er
Auto electrician
Cheers will keep an eye on it all.
