Cleaning the Radiator
toggleE
Mach E, Raptor, Ducati SF, WRX STI
I'm about to detail the Mach E and was wondering what everyone's take is on cleaning out the radiator. There are about a million dead bugs in there and I don't want to just blast it with a pressure washer. Also, what's the correct way to open the vents so I get access to the radiator grill?
There is no way to open the vents that I've ever read. I have never cleaned a radiator with anything but a garden hose, and then rarely.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
Wait until it’s 75° out and initiate a charge. The shutters will then open and you can hit it with a hose or radiator cleaner.
Second option would be to precondition for an hour to warm the battery. Drive the hell out of it for 15 minutes. Come back and initiate a charge. That might have the battery warmed enough for the shutters to open.
Last option, pull the frunk tub and hit it from the back. The fam and shroud are a bit in the way, but should be doable.
This is the best way IMO.
Yep, pull the frunk tub, clean from behind. ??
toggleE
toggleE
Waiting for it to be warm outside to detail a car is almost counter-intuitive haha.
But removing frunk tub sounds good. Ill try that. Thanks!
