chimpster23
- Mar 18, 2022
- USA
- 22 BLK GT ER-AWD / 04 Toyota Camry
I have been logging charge stats as best as I can for months now since I have had the car. I tried to trace as much as I can and make decisions as best as I can such as when to charge, temp, pricing and so forth.
I have been aggregating this on excel till date and I feel like I have maxed out my analysis for tracking this.
I am looking to see if I should monitor track anything differently or if there is a better way to summarize this data now that I have a good subset of it.
I am open to hearing any other ideas or data points from you that I should try to track and also any behaviors to change / follow based on the log.
Notes
On the kWh column, it's calculation based, as ford didn't add this on the app until months after I got the car.
On the pricing some of it is estimated while others (noted at work) are hard prices paid with charge-point
I am a movie buff, and this summer was one of the better ones vs the past few years so I was constantly at AMC....
I think very occasionally I do tap over 80%, but I am getting better with trying to stay just at it now
Notes
Location | Date | Plugged In % | Unplugged % | Distance Added | Total Charge Time | Temperature | Total Charge Added | Minutes Charge Time | Charge Start | Average Miles Added Per Hour | Month | Season | kWh added | Price | Energy kWh/ Hour |
Home | 12/1/2022 | 41% | 98% | 156 | 7:24:00 | 30-50 Degrees | 57% | 444 | Low | 21 | 12 | Winter | 50 | $ 6.02 | 6.8 |
Home | 12/2/2022 | 95% | 100% | 20 | 2:19:00 | 30-50 Degrees | 5% | 139 | High | 9 | 12 | Winter | 4 | $ 0.53 | 1.9 |
Home | 12/4/2022 | 82% | 83% | 10 | 1:05:00 | 30-50 Degrees | 1% | 65 | High | 9 | 12 | Winter | 1 | $ 0.11 | 0.8 |
Home | 12/5/2022 | 70% | 80% | 24 | 1:17:00 | 30-50 Degrees | 10% | 77 | Low | 19 | 12 | Winter | 9 | $ 1.06 | 6.9 |
Pizza / Diner | 12/7/2022 | 69% | 74% | 15 | 0:44:00 | 30-50 Degrees | 5% | 44 | Low | 20 | 12 | Winter | 4 | 6.0 | |
Home | 12/8/2022 | 61% | 75% | 30 | 1:36:00 | 30-50 Degrees | 14% | 96 | Low | 19 | 12 | Winter | 12 | $ 1.48 | 7.7 |
Friend | 12/16/2022 | 51% | 52% | 1 | 0:06:00 | 30-50 Degrees | 1% | 6 | Low | 10 | 12 | Winter | 1 | 8.8 | |
Mall / AMC A List | 1/8/2023 | 28% | 37% | 19 | 1:32:00 | 30-50 Degrees | 9% | 92 | Low | 12 | 1 | Winter | 8 | 5.2 | |
Pizza / Diner | 1/9/2023 | 23% | 29% | 11 | 0:45:00 | 30-50 Degrees | 6% | 45 | Low | 15 | 1 | Winter | 5 | 7.0 | |
Home | 1/9/2023 | 23% | 79% | 120 | 7:00:00 | 30-50 Degrees | 56% | 420 | Low | 17 | 1 | Winter | 49 | $ 5.91 | 7.0 |
Home | 1/12/2023 | 40% | 64% | 54 | 2:59:00 | 30-50 Degrees | 24% | 179 | Low | 18 | 1 | Winter | 21 | $ 2.53 | 7.1 |
Mall / AMC A List | 1/13/2023 | 29% | 43% | 26 | 2:06:00 | 30-50 Degrees | 14% | 126 | Low | 12 | 1 | Winter | 12 | 5.9 | |
Home | 1/15/2023 | 49% | 76% | 60 | 3:25:00 | 30-50 Degrees | 27% | 205 | Low | 18 | 1 | Winter | 24 | $ 2.85 | 7.0 |
Mall / AMC A List | 1/15/2023 | 38% | 51% | 26 | 2:02:00 | 30-50 Degrees | 13% | 122 | Low | 13 | 1 | Winter | 11 | 5.6 | |
Home | 1/16/2023 | 53% | 60% | 15 | 0:48:00 | 30-50 Degrees | 7% | 48 | Low | 19 | 1 | Winter | 6 | $ 0.74 | 7.7 |
Home | 1/19/2023 | 17% | 79% | 125 | 7:16:00 | 30-50 Degrees | 62% | 436 | Low | 17 | 1 | Winter | 55 | $ 6.55 | 7.5 |
Mall / AMC A List | 1/21/2023 | 58% | 73% | 28 | 2:21:00 | 30-50 Degrees | 15% | 141 | Low | 12 | 1 | Winter | 13 | 5.6 | |
Mall / AMC A List | 3/24/2023 | 45 | 2:49:00 | 30-50 Degrees | 169 | Low | 16 | 3 | Winter | 19 | 6.7 | ||||
Mall / AMC A List | 3/25/2023 | 35 | 2:10:00 | 30-50 Degrees | 130 | Low | 16 | 3 | Winter | 15 | 6.7 | ||||
Mall / AMC A List | 3/31/2023 | 36 | 2:14:00 | 30-50 Degrees | 134 | Low | 16 | 3 | Winter | 15 | 6.7 | ||||
Mall / AMC A List | 4/1/2023 | 35 | 2:05:00 | 30-50 Degrees | 125 | Low | 17 | 4 | Spring | 14 | 6.7 | ||||
Mall / AMC A List | 4/8/2023 | 33 | 1:56:00 | 50-80 Degrees | 116 | Low | 17 | 4 | Spring | 13 | 6.7 | ||||
Mall / AMC A List | 4/9/2023 | 31 | 1:51:00 | 50-80 Degrees | 111 | Low | 17 | 4 | Spring | 12 | 6.7 | ||||
Home | 4/16/2023 | 25% | 80% | 147 | 8:24:00 | 50-80 Degrees | 55% | 504 | Low | 18 | 4 | Spring | 48 | $ 5.81 | 5.8 |
Home | 4/20/2023 | 34% | 80% | 129 | 6:52:00 | 50-80 Degrees | 46% | 412 | Low | 19 | 4 | Spring | 40 | $ 4.86 | 5.9 |
home | 4/24/2023 | 37% | 81% | 120 | 5:41:00 | 50-80 Degrees | 44% | 341 | Low | 21 | 4 | Spring | 39 | $ 4.65 | 6.8 |
Mall / AMC A List | 4/30/2023 | 25% | 42% | 41 | 2:39:00 | 50-80 Degrees | 17% | 159 | Low | 15 | 4 | Spring | 15 | 5.6 | |
Home | 5/1/2023 | 21% | 80% | 160 | 8:27:00 | 50-80 Degrees | 59% | 507 | Low | 19 | 5 | Spring | 52 | $ 6.23 | 6.1 |
Mall / AMC A List | 5/4/2023 | 47% | 70% | 65 | 3:40:00 | 50-80 Degrees | 23% | 220 | Low | 18 | 5 | Spring | 20 | 5.5 | |
Mall / AMC A List | 5/5/2023 | 68% | 80% | 33 | 1:57:00 | 50-80 Degrees | 12% | 117 | Low | 17 | 5 | Spring | 11 | 5.4 | |
Pizza / Diner | 5/10/2023 | 71% | 79% | 25 | 1:01:00 | 50-80 Degrees | 8% | 61 | Low | 25 | 5 | Spring | 7 | 6.9 | |
Mall / AMC A List | 5/11/2023 | 67% | 79% | 37 | 2:05:00 | 50-80 Degrees | 12% | 125 | Low | 18 | 5 | Spring | 11 | 5.1 | |
Mall / AMC A List | 5/14/2023 | 78% | 90% | 36 | 2:12:00 | 50-80 Degrees | 12% | 132 | Low | 16 | 5 | Spring | 11 | 4.8 | |
Mall / AMC A List | 5/18/2023 | 65% | 88% | 65 | 3:57:00 | 50-80 Degrees | 23% | 237 | Low | 16 | 5 | Spring | 20 | 5.1 | |
Mall / AMC A List | 5/24/2023 | 26% | 36% | 28 | 1:32:00 | 50-80 Degrees | 10% | 92 | Low | 18 | 5 | Spring | 9 | 5.7 | |
Mall / AMC A List | 5/25/2023 | 26% | 44% | 46 | 2:46:00 | 50-80 Degrees | 18% | 166 | Low | 17 | 5 | Spring | 16 | 5.7 | |
Mall / AMC A List | 5/26/2023 | 37% | 52% | 40 | 2:19:00 | 50-80 Degrees | 15% | 139 | Low | 17 | 5 | Spring | 13 | 5.7 | |
Friends Parking Garage | 5/28/2023 | 38% | 64% | 69 | 8:01:00 | 50-80 Degrees | 26% | 481 | Low | 9 | 5 | Spring | 23 | 2.9 | |
Mall / AMC A List | 5/29/2023 | 53% | 65% | 38 | 1:55:00 | 50-80 Degrees | 12% | 115 | Low | 20 | 5 | Spring | 11 | 5.5 | |
Home | 6/3/2023 | 33% | 80% | 127 | 8:36:00 | 50-80 Degrees | 47% | 516 | Low | 15 | 6 | Spring | 41 | $ 4.96 | 4.8 |
Friends Parking Garage | 6/3/2023 | 67% | 69% | 4 | 0:36:00 | 50-80 Degrees | 2% | 36 | Low | 7 | 6 | Spring | 2 | 2.9 | |
Work | 6/7/2023 | 29% | 42% | 35 | 3:03:00 | 50-80 Degrees | 13% | 183 | Low | 11 | 6 | Spring | 11 | $ 0.98 | 3.8 |
Mall / AMC A List | 6/7/2023 | 35% | 55% | 53 | 2:48:00 | 50-80 Degrees | 20% | 168 | Low | 19 | 6 | Spring | 18 | 6.3 | |
Mall / AMC A List | 6/10/2023 | 51% | 66% | 48 | 2:32:00 | 50-80 Degrees | 15% | 152 | Low | 19 | 6 | Spring | 13 | 5.2 | |
Work | 6/12/2023 | 53% | 71% | 46 | 3:51:00 | 50-80 Degrees | 18% | 231 | Low | 12 | 6 | Spring | 16 | $ 1.37 | 4.1 |
Work | 6/13/2023 | 61% | 80% | 50 | 5:27:00 | 50-80 Degrees | 19% | 327 | Low | 9 | 6 | Spring | 17 | $ 1.49 | 3.1 |
Work | 6/21/2023 | 28% | 71% | 124 | 10:16:00 | 50-80 Degrees | 43% | 616 | Low | 12 | 6 | Summer | 38 | $ 3.36 | 3.7 |
Work | 6/22/2023 | 62% | 79% | 49 | 5:22:00 | 50-80 Degrees | 17% | 322 | Low | 9 | 6 | Summer | 15 | $ 1.34 | 2.8 |
Mall / AMC A List | 6/24/2023 | 48% | 64% | 49 | 2:40:00 | 50-80 Degrees | 16% | 160 | Low | 18 | 6 | Summer | 14 | 5.3 | |
Work | 6/26/2023 | 56% | 80% | 71 | 4:03:00 | 50-80 Degrees | 24% | 243 | Low | 18 | 6 | Summer | 21 | $ 1.90 | 5.2 |
Work | 6/28/2023 | 42% | 68% | 76 | 4:15:00 | 50-80 Degrees | 26% | 255 | Low | 18 | 6 | Summer | 23 | $ 2.00 | 5.4 |
Mall / AMC A List | 6/29/2023 | 60% | 82% | 68 | 3:44:00 | 50-80 Degrees | 22% | 224 | Low | 18 | 6 | Summer | 19 | 5.2 | |
Work | 7/5/2023 | 28% | 83% | 155 | 9:24:00 | 50-80 Degrees | 55% | 564 | Low | 16 | 7 | Summer | 48 | $ 4.32 | 5.1 |
Work | 7/10/2023 | 28% | 81% | 149 | 8:49:00 | 50-80 Degrees | 53% | 529 | Low | 17 | 7 | Summer | 47 | $ 4.11 | 5.3 |
Work | 7/12/2023 | 61% | 85% | 67 | 4:01:00 | 50-80 Degrees | 24% | 241 | Low | 17 | 7 | Summer | 21 | $ 1.88 | 5.3 |
Mall / AMC A List | 7/13/2023 | 71% | 85% | 39 | 2:06:00 | 50-80 Degrees | 14% | 126 | Low | 19 | 7 | Summer | 12 | 5.9 | |
Work | 7/19/2023 | 48% | 66% | 52 | 3:11:00 | 50-80 Degrees | 18% | 191 | Low | 16 | 7 | Summer | 16 | $ 1.48 | 5.0 |
Work | 7/19/2023 | 66% | 79% | 43 | 3:18:00 | 50-80 Degrees | 13% | 198 | Low | 13 | 7 | Summer | 11 | $ 1.14 | 3.5 |
Work | 7/24/2023 | 34% | 53% | 54 | 4:33:00 | 50-80 Degrees | 19% | 273 | Low | 12 | 7 | Summer | 17 | $ 1.46 | 3.7 |
Work | 7/24/2023 | 53% | 76% | 70 | 4:04:00 | 50-80 Degrees | 23% | 244 | Low | 17 | 7 | Summer | 20 | $ 1.90 | 5.0 |
Work | 7/25/2023 | 48% | 68% | 56 | 3:27:00 | 50-80 Degrees | 20% | 207 | Low | 16 | 7 | Summer | 18 | $ 1.56 | 5.1 |
Work | 7/26/2023 | 56% | 85% | 94 | 5:37:00 | 50-80 Degrees | 29% | 337 | Low | 17 | 7 | Summer | 26 | $ 2.62 | 4.5 |
Work | 8/1/2023 | 60% | 70% | 30 | 3:23:00 | 50-80 Degrees | 10% | 203 | Low | 9 | 8 | Summer | 9 | $ 0.85 | 2.6 |
Work | 8/1/2023 | 69% | 82% | 38 | 3:21:00 | 50-80 Degrees | 13% | 201 | Low | 11 | 8 | Summer | 11 | $ 1.03 | 3.4 |
Work | 8/7/2023 | 56% | 74% | 69 | 4:07:00 | 50-80 Degrees | 18% | 247 | Low | 17 | 8 | Summer | 16 | $ 1.92 | 3.8 |
Work | 8/7/2023 | 74% | 79% | 23 | 2:20:00 | 50-80 Degrees | 5% | 140 | Low | 10 | 8 | Summer | 4 | $ 0.64 | 1.9 |
Work | 8/8/2023 | 65% | 69% | 18 | 1:43:00 | 50-80 Degrees | 4% | 103 | Low | 10 | 8 | Summer | 4 | $ 0.39 | 2.1 |
Work | 8/8/2023 | 69% | 76% | 19 | 2:14:00 | 50-80 Degrees | 7% | 134 | Low | 9 | 8 | Summer | 6 | $ 0.56 | 2.8 |
Work | 8/8/2023 | 75% | 82% | 50-80 Degrees | 7% | - | Low | - | 8 | Summer | 6 | - |
