dan_meh
- Daniel
- Aug 12, 2024
- Alexandria, VA
- 2024 Mustang Mach-e Premium Extended AWD
- Technical Writer
I now own a MME and a Toyota Sienna. In my hybrid minivan, I don’t think about the infrastructure. It sort of fades into the background. My experience tells me that there will be a gas station when I need it, there will be a well-maintained road where I need it, and there will be a nav system from my phone to tell me how to get there. I’ve done the trip from DC to Canaan Valley, WV in that hybrid multiple times (and the tiny little econobox before that minivan).
We aren’t yet at that place with electric cars. Some places are difficult even for the vaunted Tesla infrastructure. Corridor H is one such place. It’s a charging desert with high winds, steep hills, and high speeds. Now that I’ve traversed Corridor H, I have a boost of confidence that comes with stretching out of your comfort zone. I’m old… it’s particularly good for me ?.
I set off at 3 PM from Alexandria in 65 F degree weather. After reading enough here, and a separate thread asking this fine community for advice on the trip, I charged to 100 percent and also set a departure time of 3 PM. Not that the departure time mattered a ton - it’s not like the batter was sitting at subzero temperatures, but I was trying to do everything right.
I arrived in Stephens City (greater Winchester) at the Electrify America in the Sheetz with about 65%. I didn’t baby the car in the I-66 leg because I didn’t have to. I knew I would be stopping before traversing the Great East Coast Charging Desert (GECCD). I set the Ford Nav to the EA station to precondition the battery and we arrived at about 5 PM. My traveling companion (10 year old daughter) and I got dinner at Arby’s (she the nuggets, I a chicken sandwich) and sat at the Sheetz charging and eating. Deets on that session:
I had also planned to find my way to one of the AC chargers at the state parks if I got myself into a pickle, but did I mention my 10-year-old? How much fun is it to sit at the charger with dad? So I was trying to avoid the AC chargers. And I did! It helps that the place we are staying has an outlet outside and I plugged the car in with the granny lead. Every little bit helps.
I haven’t done the return trip yet, but I must say that I feel a huge confidence boost. Previously, I did “easy” road trips in the MME Extended Range AWD 2024. I stuck to major corridors and the feeling was a lot like the hybrid minivan: I just used the Ford Nav, it told me where to stop, I did, and arrived just peaches at my destination. This was the first trip where I had to do real planning - had to pay attention to my consumption, had to make the Ford Nav do what I wanted, and so on.
I recognize that each new EV owner must learn lessons anew, which is why I’m posting this. If you’ve been around, you know this stuff. But newbies have lessons learned:
- Plugged in at 65% and pulled 150kw for a hot second - amazing/weird - but it quickly fell.
- Settled in at 70-80 kw from about 70-80, getting the gradual taper.
- At 80%, the rate fell to 34 kWh/h and stayed there until 95% - Yes, I know… I went to 95%… charging desert.
- I unplugged at about 5:38 PM with 95% in the tank and continued on.
- Know whether you are on an easy course or a hard one. If you’re traveling on I-95, the infrastructure has caught up - maybe not to full gas levels - but to a place where you don’t need to think a ton about it.
- Get out of your comfort zone and do a hard one… when you’re ready. I feel like I lived what my dad talked about when he drove around the four corners area in the 50s and 60s. “Don’t pass a gas station without filling the tank - every time, and then ask where the next one is,” he’d say.
- Slow down to make it through a charging desert. The speed limit on 48 is 65 MPH, most people go 75, and I was going 60. It only cost me about 10 minutes in time to go a bit slower and it saved my consumption.
- The MME has cards for trips - the little context switcher at the bottom of the giant screen. The Trips card shows the current consumption of “this trip.” Know what your consumption limit is by playing with settings in ABRP and keep your consumption at or under that amount. It’s hard to get passed, but don’t let pride ruin your day. Slow the eff down.
- Use ABRP, especially to see what your consumption needs to be. You can change it in the settings. Plan with an assumption of 3.0 miles per kwh, 2.5, and 2. In retrospect, it’s obvious that efficiency matters when crossing a charging desert, but seeing the difference in ABRP… makes a difference.
- Don’t be afraid to charge deep into the pack if you must: it was hard for me to sit at a charging station and draw above 80%, but I did it because I had to. Fortunately, I didn’t keep anyone waiting, but it was a real concern. But I had to be selfish in this instance because I couldn’t get where I was going if I didn’t go deep into the pack.
- ABC (Always Be Charging): the little granny charger is going to be my buffer. It’s not going to radically change my route, but it’s going to be piece of mind. I’m not Kyle Conner. I need to arrive at a charging station with between 10-20% predicted!
