Delivery/Pickup checklist
Status
Not open for further replies.
Hplbiking
Hugo
Mustang Mach e
Emgineer
Is there thread about recommended steps to do once at the dealer? OF course the obvious like inspect the car, but I have heard other say the dealer needs to enter a code to reset it. Some have suggested deleting the car from FordPass and reenter it with the bar code from the window sticker. For those that have already received your Mach e's (lucky) what tips/suggestions would you provided to make that day go ever
UW2
Los Angeles
Mustang Mach E FE
Would be nice to get this
UW2
Los Angeles
Mustang Mach E FE
Would be a good list to have. Not having such a list, yet getting ready to pick up my car, here is my initial list:
1. Drive the damn thing
2. Check lights, turn signals, etc
3. Check the center console is working in both dark and light modes
4. Turn on the music to check it works
5. Reset the Sync4 (why? just for fun?)
6. Turn on A/C to check
7. Ensure phone as a key works right there
8. Ensure key fob works
9. Program the passcodes for door and car start right there
10. Sign onto FordPass and make sure the car is synced with that
11. Run through my financing spreadsheet, verifying each item
12. Kiss the dealer goodbye (optional)
eltonlin
NorCal
FE Gray
I would add:
Check every seam for alignment, mine were all perfect.
Open and close every door, trunk, frunk several times.
Adjust the seat
Adjust the mirrors
Ensure the mobile charger is in the trunk
Listen for any high-pitched sounds coming from the displays (ala @methorian )
Hplbiking
Hplbiking
Hugo
Mustang Mach e
Emgineer
agoldman
Charleston, SC
The biggest issue at this forum seems to be PAAK.
The wifi tip someone posted today about checking the language set by mistake to UK was good, but probably has to wait till you get home unless you connect to your phone's hot spot maybe, even if just for a test at the dealer.
I'd say all the connections to your phone, key, profile, etc, are important while you are still there.
2021 Mustang Mach-E vehicles should have the vehicle's driver history settings reset during vehicle delivery to the customer. This will make sure that the estimated driving range and charge level readings are accurate for the customer. To reset the vehicle's driver history settings, go to the home screen and tap the vehicle icon in the top left corner, then tap Settings > Vehicle > EV Driving History Reset.
  • Like
Reactions: DBC
Status
