Departure settings
wenklaw
UK
Mach E AWD premium ER
Astronaut, ex MI6 agent, compulsive liar.
All
Only used departure settings once, set to medium and the cabin was like a pizza oven and the seats you could fry an egg on.
What is the cool setting anyone know? I am hoping it's the settings the car was left at? 20.5 degrees in my case, any ideas.
I dread to think what the warm setting is like.
All
None of the options are "the settings the car was left at". If they were, they would say "LAST", which is possible using Remote Start. Clearly you should try "Cool" and see if that works better for you.
wenklaw
UK
you do own a ford don’t you? Logic does not apply
Oh and remote start doesn't work in the UK, well it doesn't on mine.
kevgallacher
Kevin
Aberdeen, Scotland
2022 Ford Mustang Mach-E RWD ER
Remote start does work in the UK I use it all the time when it’s cold, I believe there is setting somewhere that disables it so maybe check your vehicle settings
hybrid2bev
2026 Rally
All
Here in the USA., departure settings are...
Cool = refrigerator / ice box
Medium = about 71 degrees F (heated seats/steering wheel on/off depending on external temp)
Warm = pizza oven
wenklaw
UK
Thanks will have a look, I assumed incorrectly that we didn't have it as a lot of the remote phone function's don't seem to work.
So probably best to set a departure time with cabin settings NONE and then remote start 10 mins before it ends? Is that even possible?
emichnov
Eric
Mass
2022 Mach-E Premium
