johndenver
- john
- Feb 16, 2023
- Denver, CO
- 2023 Ford Mach E Premium, 2020 Ford Raptor
Installed yesterday, install very simple. Basiclly this hitch looks exactly like the factory euro hitch, but the main cross tube is square instead of round. The attachment/release system is identical to the euro version, im going to order the ball part from europe as im sure it will fit.
The hitch comes with the attachment part in a nice case...once attached it gives you a 2" receiver. Of course for most trailers your going to need a rise hitch to go in it, and make sure its one of the angled ones so it clears the back of the car. I went with a 8" rise, to be at the same height as my Raptors hitch since all my trailers are setup for it.
For wiring you need: Draw Tite 118840 T-One T-Connector Harness. Plugs right into factory harness.
You can grab power for the lighting unit off the cig lighter plug in the rear of the trunk area. The purple is hot.
I HIGHLY recomend for the trailer connector wire you run it up into the trunk (Easy to do through a rubber plug under the strofoam compressor holder thing). DO NOT, and i repeat, DO NOT have the trailer connector wire come out by the hitch. Doing this is a sure bet it will get coroded and damaged. Leave it in the trunk and drape it out and close the trunk on it when using it. This way it always is clean and protected. (Done hitches on every vehicle i own for 25 years, and this is ALWAYS the best way to do the wiring if its a car).
Going to test this weekend towing my UTV on a trailer. Total weight about 2,800 lbs. Pics will follow!
--John
--John
