DTC codes
wholesome
Philipp
Mach-e 2022 awd ext
I recently bought a used 22 MME premium ext, and yesterday, after I used FORSCAN to enable hands-free liftgate, I've noticed the following DTC codes:
Code: U200D - Control Module Output Power A (also Power B/C)
Code: U0565 - Invalid Data Received From Camera Module-Rear
Code: B115E - Camera Module
Code: B15E1 - Driver Side LED
Code: B15E2 - Passenger Side LED
Code: B1495 - Hands Free Liftgate/Decklid Input Sensor
Does anyone know if I should be concerned about these or if it is normal?
Thanks a lot
DTC details:
Additional Fault Symptom :)15):
- Circuit Short To Battery Or Open
Status (-48):
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Module: Remote Function Actuator
Additional Fault Symptom :)86):
- Signal Invalid
Status (-28):
Module: Image Processing Module A
Additional Fault Symptom :)55):
- Not Configured
Status (-08):
Module: Body Control Module
Additional Fault Symptom :)97):
- Component Or System Operation Obstructed Or Blocked
Status (-08):
Module: Camera Module Rear
Status (-08):
bshaw
Boston, MA
I thought the handsfree liftgate was disabled due to a chip shortage? I’m not sure how Forscan settings can overcome not having the chip?
Many 2022s have the parts, but it's disabled. My delivered in May 2022 that was made Jan - April 2022 (yes, 4 months) had them.
KeyWestEViking
Jeff
New Westminster, BC
www.keywestford.com
Mach-E. Lightning
EV Experience Coordinator
Nothing to worry about. The two U codes were set but don't show as active. This probably means the vehicle thought there 'might' be an issue but after rechecking, there wasn't.
The B codes just mean the camera was blocked and every Mach-E I've seen has these codes. It's caused by you getting in and out of the vehicle and 'blocking' the camera so it can't see you.
Long story short, absolutely no cause for concern!
wholesome
wholesome
Philipp
Mach-e 2022 awd ext
Thank you.
wholesome
wholesome
Philipp
Mach-e 2022 awd ext
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
Today for the heck of it I ran a scan before I drove today, and soon as I got something pop up that usually doesn’t I stopped and ran the scan again. The first thing that came up when I was going around the corner on a Country Rd., Lane centering not available so I stopped. I ran scan and it’s basically those camera codes that don’t really mean anything cleared them and it didn’t come back after I drove the rest of the day. Interesting. I’m not saying that’s 100% but just in case somebody else runs a scan and gets these codes the Ford dealer saw these one time and they could be anything from a bug or rain or anything where the camera was blocked for a second or whatever or couldn’t read something, that’s my opinion
Ford Mustang Mach-E DTC codes IMG_7797
