Eibach Sway bars now avalable for the Mach E
The clunking sound that @chiendat has seems hollow but metallic. Not sure what might be causing that. Possibly a damper? The hollow feeling the sound might just be acoustics around the microphone though. It’s hard to tell without being in the vehicle to hear it first-hand and possibly feel it through the chassis. 🤔🐩
ESJB
Canberra, Australia
Select SR RWD 2023.75 (Aus)
It feels like something is falling off 😂. I’ll put on the old bar to see if it still sound, if it is, it’s Ford’s problem
Whilst you're down there, check the play on the ball joint on the end links, where they bolt onto the bar (and maybe the other ball joints where they bolt to the chassis). I'd be surprised if that was the culprit though. Agree with everyone else that something's just not bolted tight enough.
chiendat
Dat
Fredericton, NB
2023 Mach-e GTPE
It is only sound when the vehicle is rocking side to side. If I go directly straight at a speed bump, it would not sound at all.
Definitely strange…
Definitely strange…
This would indicate that it has something to do with the anti-roll bar if the rolling motion imparts the sound. The hollowness of the sound would make me want to investigate the frame brackets and bushings first. 🤔🐩
highland58
IT Solutions Architect
I am wondering who you guys would trust to install these in the Seattle area? Thanks.
Did you get a good answer, did you get the work done? I have the same question and I am not able to do this myself.
