Electrical system drain, service required
Embargo10
Travis
Plattsmouth NE
2021 Mach-E GTPE
I have a 21 gtpe and woke up to some fun this morning. Overnight I received a couple of messages in my FordPass App about a electrical service drain and a security system alarm. When I went to check on my car I couldn’t get any door to open. I tried the unlock button on my key and no response from the vehicle. I ended up getting the frunk open by jumping the car. I removed the panels from the frunk and disconnected the negative terminal on the battery and let it sit for 5 minutes. After I connects the negative terminal I still got no response from the car. I ended up jumping the battery and the car came to life. I got everything back on the car and decided to take it for a drive. Upon startup I got an error about a suspension fault but the car seemed to drive just fine. As of right now it appears to be fine but I’m nervous to take it anywhere. Anyone run into anything like this?
Ford Mustang Mach-E Electrical system drain, service required A5340C56-2F69-410F-A42C-6BDEFAB7F4E0
Ford Mustang Mach-E Electrical system drain, service required 053BA80E-01C6-42AA-BEC4-737EE3B18835
Ford Mustang Mach-E Electrical system drain, service required AF10574D-3EEB-4831-8EB7-006A12F2D42D
Ford Mustang Mach-E Electrical system drain, service required 011A86B6-387E-4AC4-919F-2C61A58A318D
Embargo10
Travis
Plattsmouth NE
2021 Mach-E GTPE
That’s what I was afraid of, thanks for the quick reply. I will schedule an appointment and post any updates.
Reactions: OWG
Ford Motor Company
Official Ford Account
Hello! Send us a private message with your MachE’s VIN and current mileage. Allow me to see what I can do to assist. Thanks!
Embargo10
Travis
Plattsmouth NE
2021 Mach-E GTPE
Wanted to report back after I took my car into service. I was advised that they found the following codes U200D:15, U200E:15 and U200F:15. They found SSM 50077 for this issue. They ended up reprogramming the RFA module to the latest calibration using FDRS, cleared codes and verified everything cleared. They also found codes U0103:87 and U0100:00 and found TSB 21-2405. They reprogrammed the GSM to the latest software level using FRDS and verified everything cleared.
ripperAZ
Ripper
AZ DESERT
Good to hear about a quick service success keep us updated if anything else goes wrong. I sold my GT after it bricked three times. Complete voltage meltdown and a 60 day repair. Made a nice profit on the private party sale though after they got it running
I have a premium on order and I’m very worried about the continued issues I keep reading about with cross battery and voltage problems
Beesinspring
Lennox
LA
Used to have a Mustang Convertible V8
I got a shift system fault error and then the car went haywire with lights flashing on the exterior and put itself into deep sleep mode. I can't even get in the doors now. I have to have it towed in. This is the third major problem I've had with the car in a year. I'm beyond disappointed.
BillPitman
Pa.
Ford Escape, ‘21 J2 Mach e, 2024 Maverick Hybrid
1st time for this message… “ Electrical System Drain Service Required” there is an electrical drain………
this was at 4:13am this morning….
however, now when checking widget,9am, voltage is showing as 13v., the 12v battery is being maintained! Correct?
it would seem to me some how the software logic and sending messaging are out of sync. Instead of seeing if the system will turn on & maintain the 12v battery, it sends out the messaging first….. Am I understanding this?! Bill Pitman
Bucket
Pearland, tx
2017 edge 2022 mach e premium
I got this message a few minutes ago, but I am schedule for service next Monday for Connectivity so add to list. If I keep having issues with this car it will be good-by.
Oklahoma
MME Premium AWD, ER: 2021 silver & 2023 orange
Physician
do you mind if I ask what happened with this car? What fixed it and did they say what caused it? This is my current situation and the dealership is saying they are unable to get into the car at all and will have to have some specialist come in to try and open the car, but my house keys, license, entire life is inside the car…. Thanks
