Enter Passcode Prompt
J5hort
JS
MA
2025 Mustang Mach-E Select AWD
Hey all, as the secondary driver of the MME, I do not carry a FOB and (at times) do not have my phone on my person to use PaaK. I have been using the door code to enter the vehicle and then the passcode on the display to start the car. I wanted to see if anyone else has experienced a delay in the passcode prompt becoming available and if there is any way it can be immediately accessed. Seems like it takes a while to show itself. I have never had an issue using this method, just want to check if there is any way to immediately get the prompt.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
No way that I know of. And I’ve been trapped for over an hour at times hoping the passcode prompt will show. Number one reason I carry a fob. If the passcode showing up was reliable, I wouldn’t worry about PAAK not being recognized at times.
Jimmy2
Jimmy
Wilmington NC
21 MME Premium 4EX; 23 MME GTPE Vapor Blue Met
You are a brave soul.
J5hort
J5hort
JS
MA
Never had a problem with using passcode..and it usually comes up within a few minutes at the latest. To put things in better context, when I go out with MME, I usually have my phone and use PaaK, but there are times (usually when out in the yard or garage) when phone is not with me and I need to gain access to the car or to move it for washing or it is in the way. There have been times PaaK has not responded and I use entry code then passcode. Those would be the use cases.
Motomax
Max
VW GLI, 4Runner
Passcode prompt shows up shows up pretty much as soon as the sync system is finished booting for me. My only issue is that CarPlay will sometimes make the passcode disappear.
J5hort
J5hort
JS
MA
Do you press the start button when you get in? Cant remember what triggers boot up... entry code?
phil
LS400
"Never had a problem with using passcode..and it usually comes up within a few minutes..."
Imagine that! A car that starts "within a few minutes"! What will they think of next?
Ford Mustang Mach-E Enter Passcode Prompt 1654915055527
J5hort
J5hort
JS
MA
... at the latest. Sometimes immediate, but not consistent.
Motomax
Max
VW GLI, 4Runner
Yeah, nothing happens if you don’t push the button. Well I haven’t noticed anything lol
