Excessive cooling fan noise when using 1pd
tfitzgex
tom
Portland Oregon
2021 Mustang Mach-E Premium extended range AWD
I find myself hearing the cooling fans go pretty loud when using 1pd in the city. It didn't used to be that way. Over a year ago I had my HVBJB replaced and the tech failed to fill the coolant properly and caused a failure in a pump. A different dealer repalced the pump, and the motor temp warnings went away. Since then I haven't had a warning or error, but have had several instances of AWD not available after romping on it. The fans are very loud even on nights where it is 35 degrees.
That doesn’t sound right. Verify both coolant tanks under the funk panels are still full.
tfitzgex
tfitzgex
tom
Portland Oregon
Can anyone give me your average temps for primary and secondary motor coils? I am seeing a 15 degree difference between the two. (carscan)
