Find charger stations in nav?
gduprey
Gerry
Rehoboth Beach, DE
Mach-E X4
Howdy,
I feel almost stupid on this, but yesterday we took a road trip. It was a few hours long, but not so long we really needed to stop and charge. However, halfway in, I was asked where there are chargers "just in case". I couldn't figure that out using the cars nav.
We have a Tesla too and on it, there are icons on the map showing you where the nearest charger. You can zoom, scroll, etc to scan around looking for nearby chargers, even when you don't "need" one.
I was able to revert back to the Ford app and it found/listed nearby chargers (before it crashed -ugh), but I tried searching here/googling/reading on how to show chargers in the nav on the Mach-E and couldn't figure it out. I feel dumb because there must be some way to do this, but digging through menus, settings, etc, etc and nothing.
Is showing nearby chargers in the nav (like it shows restaurants) and/or searching for close by one possible in the nav? Or do you have to use your Ford app on the phone?
I have planned a longer trip with the nav and it did suggest charging stops on that one. So it's "in there". But how do you search (visually or generally by proximity) when you just "driving around"?
I generally use ABRP when going longer trips, but there must be "something" available in the car itself (displayed or searches).
Thanks and I apologize if this is a case of "it's right in front of you" selective amnesia
agoldman
Charleston, SC
I think it only shows certain chargers and private buildings may not show as I have seen to be the case, but open the Nav, and then down the bottom left there should be a settings button of some sort and you can change what shows on t he map.
That said, I found the chargers search to be an afterthought at best, and I would have though there would be a prominent button for Finding Nearby Stations! If I'm missing a feature that would "Direct6 Me to A nearby Station list with Station Status, like Tesla has, please enlighten me.
gduprey
gduprey
Gerry
Rehoboth Beach, DE
Mach-E X4
I did look at the settings in nav and there are options for what to show, but nothing about chargers. If it's there (or in vhicle or charging settings), I'm missing it.
And I'd expect to find something because you would most likely need options (all chargers, DCFC only, etc, etc)
Tampamike
Tampa, FL
‘24 Mach E Premium RWD
You can use voice command “show nearest charging station.” It gives you a list on the screen which you can then select.
agoldman
Charleston, SC
Or the what's near button on the Nav screen lists chargers.
