Front row full seat back cover
AOSK
Diamond Sponsor
Zac
california
Mach-E select
Gullwingdmc
Chip
Boston, MA
This is awesome!! Any chance of getting them with an embossed Mach-E logo above the pocket?
AOSK
AOSK
Diamond Sponsor
Zac
california
Mach-E select
o_Ono plan for that, we try to make it has a oem look
Nemy
Portland, OR
2022 DMG Mach-E Premium X
Looks great! I'll definitely be getting one once I have to flip the car seat around.
Gullwingdmc
Chip
Boston, MA
@AOSK Just got mine. I’m confused about how these pieces attach to the seat
Ford Mustang Mach-E Front row full seat back cover imag
AOSK
AOSK
Diamond Sponsor
Zac
california
Mach-E select
Hi! place this into the seat gap if you would like this seat cover to be more tighten
orangethunder
On order
To clarify since I had the EXACT same question, pull the stretch part and plastic circle part to the front side of the seat backrest and push them into the gap behind where you butt goes. They hold in place well and tighten the fit. One worked its way out initially but I stuffed it back in and no issues for couple months now.
Gullwingdmc
Chip
Boston, MA
Ahh ok. So use two per seat, not one. I thought the two elastics attached to one.
Gullwingdmc
Chip
Boston, MA
Thanks! Any issues with those clips scratching the seat?
Gullwingdmc
Chip
Boston, MA
theyre tucked behind anywhere visible and the plastic in rounded and smooth so I didn’t/can’t even look.
Nice! How hard was it to stretch the top around the headrest posts?
orangethunder
On order
Not hard. I didn’t do it initially (just had the Post through the hole) then saw a picture somewhere showing it being stretched and gave it a try. Took a minute for all four holes, looks very good.
Gullwingdmc
Chip
Boston, MA
Sweet! Thank You
SightUp
Nebraska
Mach E
ARNG
OK. So I had the same problem. To help clarify, the OP's original picture is how it should look. Then, put them through the seat cracks flat. Once they reach the other side of the crack, they need to go vertical so they cannot go through the cracks the same way.
