Full accessory power on problem
Ryanh99
Ryan
Vancouver
2021 Mustang Mach-E Premium AWD Standard Range
Hi Mache owners,
I’m seeing the attached messages on my dash board when charging in my parking lot. One says full accessory power on and when I go into charge under vehicle, it says charge comfort level warm.
should I be paying attention to these messages at all? I’m more concerned of safety issue.
Ford Mustang Mach-E Full accessory power on problem DFCCA33E-63D6-45AA-8BE7-3101AB2BA286
Ford Mustang Mach-E Full accessory power on problem 56C4BF71-332A-475D-890E-46E89AD4BEBC
richsi
Rich
SF Bay Area, Fremont/Union City
2023 Tesla M3P, 2024 Ford Maverick Lariat
Hi Mache owners,
You have programmed your vehicle while charging to include warming your interior to the "Warm" setting. Look at your "Departure and comfort" setting it's clicked on! Very normal if you have this setting in place. Has nothing to do with the charging of the batteries being in a warm state.....no worries!
hybrid2bev
2026 Rally
Hi Mache owners,
Sounds like your car is on. Is the start button blinking? Press the start button once without your foot on the brake, should turn it off.
Hi Mache owners,
Those are actually two different messages. First message on the driver's display means you are in accessory mode. Very normal.
The charging screen on the center display says you started charging around 5:30 and expect to reach 100% around 2 am. Then it looks like you have a Departure Time set for 7:15 am and it will heat the cabin to the warm setting. Not sure about your car but in my car "Warm' is pizza oven temp.
Ryanh99
Ryan
Vancouver
Thanks! My "Warm" is not that hot but the heated seats turn on max and also the steering wheel. The cabin temperature seems to be around 26 Celsius.
Crilly
Dale
Hartland, Wi
Are the seats on when this picture was taken? If so you could be draining the 12 volt battery.
Ryanh99
Ryan
Vancouver
By seats on do you mean the heating?
Crilly
Dale
Hartland, Wi
Yes, heated seats.
