Grinding/Clunking Noise
tjfuller15
Tiffany
2021 Mustang Mach-E Premium
Can someone tell me I'm not crazy and they hear it too?
I took my car in because there was a knocking noise coming from the rear. They diagnosed a failing rear trailing arm so they replaced that. After I picked her up I started to hear like a creaking noise, think you're getting up out of an old rocking chair. Took her back to the dealer but they said they couldn't replicate it. Week later, there's this new clunking/grinding noise coming from the rear. It happens when I go over any bumps or making any slight turns. I started recording it so that I have some evidence when I take her back in. Anyone experience this noise before? If so, what is it?
The video facing the sky is the creaking I was hearing at first.
mike404
Burlington ON
2021 Mach-E premium
Logistics
See if you can look at the axle boots torn or leaking fluid?
tjfuller15
tjfuller15
Tiffany
Well, thought I would give an update in case anyone starts to hear a similar noise. Got her back this morning and I'm not hearing the noises so far ??. A bunch of new bolts, nuts & washers. They had to replace the stabilizer bar link, cross member (rear subframe), rear knuckle/ bushing repair. Also got an alignment.
