Heat pump in new models?
Mache_Nor
Norway
MachE LR RWD
Also keep in mind that the Mach E has like 15 (ish) extra kWh battery than the Teslas you compare it with. Again, we don't need to overcomplicate it; Sure, you can find the extreme use cases where it does not make sense - but most users are not extreme cases. Take Norway for example; It's about 0-10 degres (celcius) in the winter on avarge. Heat pump in this environment is just so much better. I understand that we as buyers trying to justify our investments while Ford says whatever it has to say to sell cars, but heat pumps (air to air versions) are a superior technology.
