Heated Steering Wheel
FrankieD
Frankie
Atlanta, GA
2023 Mach-E GTPE
Just got the car yesterday and started using the heated steering wheel. It doesn’t seem to get hot - just mildly warm.
Is this something that I should be concerned about? Is the heated dependent on temperature set for the HVAC
Jeffvisor
Jeff
Harrisburg, PA
Ford Mustang Mach-e
I think it's more weather related the colder it gets the hotter the steering wheel gets. Mine gets very warm when it's cold out.
FrankieD
FrankieD
Frankie
Atlanta, GA
2023 Mach-E GTPE
Got ya. Thanks.
FrankieD
FrankieD
Frankie
Atlanta, GA
2023 Mach-E GTPE
another random question - would appreciate the help if you know. For the front camera washer - is there a setting I need to enable for it to work?
Jeffvisor
Jeff
Harrisburg, PA
Ford Mustang Mach-e
Not 100% sure but I think when you squirt the windshield it squirts there as well. No setting that I am aware of. I hope this is accurate but if not someone will chime in with the correct information.
FrankieD
FrankieD
Frankie
Atlanta, GA
2023 Mach-E GTPE
mot 100% sure but I think when you squirt the windshield it squirts there as well. No setting that I am aware of. I hope this is accurate but if not someone will chime in with the correct information.
Thanks. Tried that and didn’t work. But will see if other have any idea
markboris
Sonora, CA
nuMach
vancouver island
2025 GT
eng tech
steering wheel temp adjusts with the drivers seat heater level.
and on high its pretty darned warm.
joes723
Joey
Black Diamond
'22 GTPE IBSM "LITHEUM"
you have to activate the front windshield washer for at least 2-3 seconds and the front camera washer will spray. If there's any air in the lines though it could take a couple extra seconds.
FrankieD
FrankieD
Frankie
Atlanta, GA
2023 Mach-E GTPE
I tried that and nothing. Does the level of fluid in the reservoir make a difference?
joes723
Joey
Black Diamond
i would say its possible it could make a difference but unlikely if you're getting plenty of washer spray on the windshield and rear window.
