Help Mechanic Forscan
Homestead
Oregun
23 Mach-E, F-350
Retired Engineer
ok, If it was causing you problems with the radio off then I would find someone with an oscilloscope to look at the output of the amplifier with the radio off. Ford service probably has one. If there is a
signal there then they can work on the cause.
Woeo
Woeo
Fusion Energi
Take your noise app and see if another MME [[or a few--your dealer might help] readings are similar under the same conditions, i.e, the radio is off/sound down. If no low hum present in the others, then you can discuss with the dealer how this is an issue with your car.
Manfredo
Los Angeles, CA
2023 Ford Mustang Mach e Premium 4Xe
Thanks guys, good suggestions. After a day of quite a bit of driving with the amp disconnected it’s the first time in 2 months, since I got the car, that my ears feel pretty much normal.
