How To Safely Lift Your Mach-E (Jack Points)
HughJazzol
Norman
Miami
2024 MachE Premium RWD
Project Manager & Swim coach
Thanks for this video, almost 2 years later.
The car can only be lifted at the 2 spots that have the arrows. Fine. If jacking it up, where could a stand be placed then? Right next to the lifting point on either the right or left side of the jack?
Pretty much the entire rail that has bolts on it can be used to lift or stand the car with so lifting near the arrowed spot or placing a stand near it is fine. Of course, you only want to lift one corner at a time unless you're using a load spreader to lift the side of the car (I use a load spreader to lift the side of the car and place the stands under the arrowed spots). There are some cars that you can't do either of those things with. In those cases you either need to lift the wheels and then place a stand or use JackPoint jack stands on. If you want to be safe and have some bucks to burn the JackPoint jack stands are the bees' knees. ??
HughJazzol
Norman
Miami
bees' knees. ??
Wow, those are nice. And expensive. And bees like them. I'd never seen them.
Back to reality...
So I have to lift and stand the rear, THEN the front, or viceversa.
Back to reality...
The Jackpoint Jack Stands are seriously badass. Yeah, pricey too. ??
Yes, one corner at a time unless you are using two floor jacks or a load spreader. ??
